I performed the same test on the right channel and achieved the same results, about 170W RMS output at 1Khz.
I then performed a test driving both channels at 1Khz until I observed clipping on both channels. The picture below shows output on both channels. at 33V RMS which translates to 136W RMS per channel which again is well within specifications for a receiver rated at 125 W per channel.
I increased the volume a bit more and at about 150 Watts per channel there was noticeable clipping at 1Khz.
To test the protection circuits I increased the volume until there was significant clipping with both channels driven. I wanted to make sure that the 2325 could withstand some abuse and not fail.
At about 175 WPC the 2325 went into protection. I reduced the volume and after 5-10 seconds it came out of protection and functioned normally. I repeated this action two more times and then figured that I should not tempt fate any further.
The output heat sinks were quite warm at this point but again not alarmingly so.
The speaker dummy load whoever, was too hot to to touch more then briefly. I definitely was stressing it's capabilities during this test.
I repeated the dual channel test at several frequencies up to 20Khz. At the higher frequencies the amplifier did not exceed the 125 WPC rating as much as it did at 1Khz but it within specs at 125WPC.
Definitely a very capable receiver.
