Substitute for C900 F92A transistor
azemerov
Hi, I'm looking for a substitute for a transistor marked as "C900 F92A". The transistor was used in MCS 3235 receiver. I guess some early 80-s.
Thank you for any advice.
2sc900
there are couple subs available. post up the circuit and i'm sure someone with more knowledge will point you in the right direction
Unfortunately I don't have a circuit and wasn't able to find it in online resources. The transistor is used in pre-amplifier, more specifically in a tone-adjusting cascade.
i would think that a ksc1845f should be fine there. watch the pinout
the 3233 uses a similar circuit(i assume anyway) and is listed as 2sc900e,f or 2sc1335e,d
hopefully someone more knowledgeable will come along as there are other possible subs
