Its permmagnevox you want fieldmagnevox.
The ones I was referring to have coils of wire instead of permanent alnico magnets in the motor assembly they require a separate power supply or for the feild or you'll barely get sound out of them.
Alnico is good, but it loses magnetism over the years. Feild coils get remagnetized every time you put current through them, so your motor never suffers age fatigue...
My personal opinion is that they are some really excellent drivers...
The alnico version should be alot of the same good stuff, but without the need for a separate power supply...
Don't most field coil designs use the coil as the filter inductor for the power supply? That eliminates the need for a separate supply. Maybe this is only applicable to class A amps with constant current draw. Not something I've studied...
Jack
