Fascinating thread!
A long-stored SX-1010 was given to me by the original owner some time ago. I was assured it was working. Physically, the unit needed cleanup, but was in pretty stellar condition beneath the grime. Fresh tung oil on the cabinet, and it's beautiful! Before powering it up, I took the bonnets off and was alarmed by how toasted the Power Supply board in the unit's underbelly (AWR-054-A) was. Some of the cap covers were shrunk and the board had a good suntan. So I replaced all the electrolytics on the Power Supply board, and while I was at it, I replaced the 'lytics on the topside Power Supply board (AWR-053-A), and since I had a bunch of Panasonic FCs, I did the Equalizer Amp board and the Control Amp board, too. My main 18,000uF power supply caps look good, no leaks or swelling, but I put a 680uf 63V Panasonic FC across the terminals - something I saw done on an old Sansui.
I powered up the unit and set the bias - though the manual says to connect 8 ohm resistors across the speaker terminals when setting the bias, so I did so. Both channels were at about 35 mV. Everything seemed a go, relays clicked, etc. so I hooked it up to speakers. I have full stereo, but a little THHHH occasionally in the lower frequencies. The sound did not seem to have the openness of soundstage that I was expecting from experience with my old Marantz 2270. Worse, on AM & FM, I have very faint - all but inaudible - staticky sound on the left channel (unless I depress the Mono switch, which would be ok for AM, but helps me not on FM). Disappointed! So now I'm studying the schematic to troubleshoot the tuner section, but I'm also wondering if there may still be some sunburn to be repaired on the underbelly Power Supply board? Any suggestions?
