Will add those 6 caps. Do you want me order 1 spare of each or just get the exact number of components? Would save me money but I won't have any back up if something goes wrong.
You are ADDING the 1n4004 diode to prevent what has already happened to you from happening again, every time the relay turns off, the magnetic field's energy has to go somewhere, so it makes a negative voltage pulse that destroys a little bit of the Q7 junction every time, the diode shunts this energy away from the transistor, at the cost of a few MILLISECONDS more time for the relay to disengage...
Pioneer did the diode thing on newer and higher end models as part of the design later on.
I was thinking about the process last night and something kind of troubled me. Something that might have gone wrong or neglected along the process. When I applied (more like SMUDGED a big blob) the thermal compound for the first time onto the new transistors, a considerable amount might have gone into the sockets carried in by the transistor leads. Would that cause any inconductivty and cause the relay to disengage? Hence the volume fading out and coming back? Just a shot in the dark.
Practiced de-soldering and re-soldering. I think I fried the circuit board around where I re-soldered a bit. I might have held the iron tip for too long on the pad, I had to try with the vacuum pump several times to get the molten solder. The board was too small (1in. X 2in.) and it was standing on a switch attached to the pad so it was hard to keep it still. I think it will be a little easier with the desoldering braid.
ZeroJunk, is that a Zetex I spy in the Q6 position?????!!!!!!!??????????!!!!!
Flux is corrosive.
From an earlier post (10-18-2008)... I replaced both of my originals with two in series of Fairchild UF4004 diodes (mouser part #512-UF4004_Q) each.
On 1010 Power Amp Board AWH-032-0, I'm wondering why you replaced diodes D7 & D8, which were each originally a single 1S1885 diode (rating: VRRM 100 Volt, IFSM 66 Amp) with two Fairchild UF4004 (rating: Repetitive peak reverse voltage 400 Volt, Peak one cycle surge forward current 30 Amp) in series. This seems like less protection rather than more in terms of the current capability of the replacements. Am I missing something?
I attach ccheath's illustration of the components from his earlier posting and a pic of my original unmodified board.
