4 caps and 2 transistors??? How come I circled 8 components then? What is extra?
markthefixer said:Sometimes the locations where the circled orange cap are, use electrolytic caps instead of those, which can stay.. Those are solid caps that don't deteriorate and can stay. Until eyes are on the caps, you never know what they used. The replacement film caps and the orange caps don't have a polarity - almost everything else does.
The pictures I circled all the components and discussed on was LBW's board anyway. I will get back to that subject with my own PP Board in a minute. Meanwhile, is the SUPED-UP list of parts above sufficient or do you need more details?
P.S: The lettering is on the CURVED side of ztx1056
The supports are pinched gently in above the board until the board will slide up top the pinch point and the board wiggled up a bit to the pinch point, repeating at each of the corners in a circular fashion, working around the corners gradually.
Get the board into a comfortable position for front and back access and then try not to flex the wires. I work on the receivers with them on their sides, transformer down, on a lazy susan turntable. Your best acccess should be directed at the solder side of the board. Be careful not to drip solder elsewhere into the unit.
Match up the values (uF) of the can shaped capacitors old to new (it's printed right on them and what I was looking for with the list - like 330uF 25v not 647-UPW1E331MPD) and notice that there is a stripe on each of the cans which denotes the negative terminal. As you remove the old, look for a plus(+) silk screened / printed on the board by the other capacitor wire, and put the stripe of the new cap in the same place.
The transistors are read C - B - E with the lettering facing you,the flat facing away, and the leads facing down. The E for the transistor symbol has the arrow, and the B is the line that the arrow is pointing away from (for an npn transistor, on a pnp the arrow points AT the line) and the C is the other line connecting to the B.
Every component that is removed on the board (4 caps and 2 transistors) has a replacement.
Like I said we get the protection working, then we start on the amp.
two:Q6, Q7 522-ZTX1056A $1.51 ea NPN TO-92E ebc 150v 3a 1w (Vce(sat)=0.3v @ 3a) 120mhz 30-1200 hfe relay driver transistor
eventually I will add the Q designations on each of the replacement transistors as well:
page 9 post 124
sx-1010 AWH032 amplifier board x 2 boards
Q1 Q2 Q3 2sa726 to-92 bce : 512-KSA992FBU (ln)to-92 ecb 120v .05a .5w 100mhz 150-800hfe
Q4 2sb528 to-202? bce : 512-KSA910YBU to-92 ecb 150v .05a .8w 100mhz 40-240hfe
Q5 Q6 2sc1451 to-39 npn ebc : 512-KSC2310YBU to-92 ecb 150v .05a .8w 100mhz 40-240hfe
Q8 2sb528 to-202? bce : 512-KSA1220AYS to-126 ecb 160 1.2a 20w 155mhz 35-320hfe
Q7 2sd358 to-202? bce : 512-KSC2690AYS to-126 ecb 160 1.2a 20w 155mhz 35-320hfe
Q10 2sa740 to-220 bce : 512-KSA940TU_Q pnp to-220 bce 150v 1.5a 25w 4mhz 40-140hfe
Q9 2sc1448 to-220 bce P: 512-KSC2073TU npn to-220 bce 150v 1.5a 25w 4mhz 40-140hfe
Q12 2sa733 to-92 ecb : 512-KSA992FBU (ln)to-92 ecb 120v .05a .5w 100mhz 150-800hfe
Q11 2sc945 to-92 ecb : 512-KSC1845EBU (ln)to-92 ecb 120v .05a .5w 100mhz 150-800hfe
at...
I haven't the slightest idea of the location of the new part (512-1n4004 conventional rectifier 1a 400v )?!?!?
Are we sure they are salt rings? If they are, that means someone, some MORON, threw it into a corner by the ocean where the conditions are extremely damp. I might as well get that 1 Liter of alcohol and start cleaning once I desolder all the parts THEN solder the new ones on.
Mark, this is a quote of yours:
According to your quote, I should look for the PLUS (+) on the board and put the NEGATIVE (-) lead of the capacitor (striped side) in there???
