LWB
Well-Known Member
Salty transistors
I think we're talking about all the transistors, everywhere they are, on every board. The conductive salt that can accumulate on the undersides of each and every transistor case, where the three base, emitter and conductor leads protrude from the transistor, will screw up your voltages unless you clean off the salt. I would try a small brush with fluffy bristles that you can wet with isopropyl alcohol to wash/brush the salt crystal accumulations away, to clean the transistor cases.
I haven't been able to find the original posts on this salty transistor issue.
