yup, good price, use a LIGHT touch...
I think I will be more comfortable with something like this:
http://www.thesource.ca/estore/Prod...line&category=Soldering+Tools&product=6412102
The desoldering iron with bulb looks pretty bulky.
www.mouser.com
534-4662 to-3 mica insulator $0.16 each (get 8)
532-249 1 oz thermal compound $4.71
or
532-250 2 oz thermal compound $6.45
863-MJ21193G pnp to-3 250v 16A 250W 4mhz 8-75hfe $3.83 for 2sAxxxx or 2sBxxxx transistors
863-MJ21194G npn to-3 250v 16A 250W 4mhz 8-75hfe $3.83 for 2sCxxxx or 2sDxxxx transistors
(the 1010 lists several different parts numbers for them)
512-KSA910YSHTA $0.07 ea
The only question is with the thermal compound, if it is 1 ounce of weight, or 1 fluid ounce, a huge difference. If it is 1 ounce weight,it should be enough for 8 transistors, if it is one fluid ounce it will be maybe three times the volume - and the catalog isn't helpful in figuring out the difference....
Mark, is there a way to put on the new output transistors and power up the unit without damaging or blowing up anything else?
