and I'm quite a bit OCD...
In the past I would have just quoted the list and rearranged it to work with it (DID I check THAT reading??) and keep track of what I was doing. But in calling attention to it, I don't have to repeat that for every subsequent set of readings.
Multiply that by 5 to 20 or more threads a day and we're talking about some significant amounts of time here...
back OT:
Any parts replacements since the stv lead (Broke? grounded? etc???)
which transistors are original, which are replacements and what are the parts numbers of the replacements. What other parts were replaced by you. It helps when trying to "trace the lightning bolt"...
From the numbers in those readings there are are just a few working transistors on that board. That it passed sound is surprising. Lower voltages aren't as worrisome, pushing sound in might turn them on, albeit with a lot of distortion, but the ones with too much emitter to base voltage are worrisome...
I was hoping that there were more probe placement errors than blown transistors. That hope is diminishing.
Quite frankly,
out of circuit 6 way diode transistor tests(see post #11) are warranted on everything (I expect q4,q4,q6 may test good) and a sound investment in time and effort.
