merlynski
Curmudgeon Electronicist
Check for bad soldering on the pin 8 of the control amp, reflow solder.
Pins 8 and 5 measure close to the same (inputs) but 3 and 1 (outputs) are very different. I think there is a problem on the Control Amp
Stereo/Mono pins look ok.
Switch and Volume Aux pins 21, 22 look ok.
Control Amp pin 5 right in, (16.7mv) should be the same as Switch and Volume pin 28 right out, (0.5mv) but pin 28 is lower. Please recheck the reading for pin 28. Verify 0Ω between them (power off) also.
Then we will compare ac voltages on the control amp.
Big thank to you already at this time.
