sx-780 power capacitor replacement
does anyone know a supplier and part number for the 50v 8000uf capacitors in the sx-780?
mouser.com:
647-UVZ1H682MRD 6800uf 50v $ 3.57 ea (capacitance a bit low) 105 degree c
647-UVZ1H103MRH 10,000uf 50v $ 6.81 ea (capacitance a bit high) 105 degree c (recommended)
standard listed value seems to be 8200 uf
The 85 degree c part:
647-UKW1H103MRD 10,000 uf 50v is $ 6.04
so the difference in cost is not that great for the higher temperature, longer lasting part.
There are only two 8200uf caps stocked, and they are xicon caps. :no:
140-LS822M1H-2550-RC 50v $3.50
and
140-LS822M1J-3535 63v $6.94
The added complication is that the xicons are "snap in" which means a broader lead that is somewhat springy. I cannot tell whether or not the original caps are snap in, or just straight in soldered wire leads.
Using a snap in may involve enlarging and moving holes. When using regular leads, they can be bent to fit much easier.
Hi Mark, I installed the 10,000uf caps and my receiver works great Thanks for the help.:banana:music:
