SX-780 Caps
CohibaJoe
AK Subscriber
Just got in a Perfect SX-780...
Will be recapping...For the Tall Boys..8000uf 50V
Cannot seem to find these...Can I go up?
10000uf 63V Nichicon's work nicely. I did mine about 2 years ago, and the part #'s are in the thread somewhere. Got them @ Mouser.
Yes, a common value is 8,200uF. The next common value is 10,000uF, but I bet you could do 12,000uF. Going up in voltage is OK too. Looks like those are standard 10mm lead spacing caps, probably 35mm diameter?
I use mouser p/n 598-SLPX822M050C4P3 for the sx-780's I have done..I bypass those with 1uf 250v film caps..usually the ones found at rat shack work fine.
Going thru some threads....this was also used.
647-UVY1H103MRD Nichicon 50volts 10000uF
Still looking....
Still looking....
I used these for the 780 I did a month or so ago: 647-UKW1H103MRD
http://www.mouser.com/ProductDetail/Nichicon/UKW1H103MRD/?qs=kArNe9LFxXlXU/0N8Vy%2byg==
I tried snap-ins, but the lead spacing was wrong and I couldn't figure out how to engineer an elegant solution, so I used the 647-UKW1H103MRD instead. They dropped right in, and have been working ever since.... :)
OK...This is going to be my list:
647-UKW1H103MRD 50volts 10000uF Nichicon
512-1N5404 conventional rectifier 3a 400v Top
512-1n4004 conventional rectifier 1a 400v Bottom
Nichicon PW/PM for Power Path (Dark Blue and Black caps)
Nichicon KL for Audio Path (Orange and Light Blue caps)
Noticed in some thread the 2 rows of rectifers should be replaced.
Also, another thread said to leave alone the Tuner as a recap may
throw the alignment out? Since I do not have a scope (maybe it time to buy one). I will recap the Tuner and I did not have a problem with (2) SX-1050's I did. I am going to use the KW as to the VY for the Big Cans. The KW has 2000hrs with the VY 1000hrs.
If someone what's to Add I will be waiting as I will be placing my order by the Afternoon.
I would defer to the expert opinions regarding the tuner.
There is a 780 thread that I started a while back, when I did mine. Under careful guidance, I was able to successfully re-cap my 780 tuner without issue..... at least as far as the capacitors were concerned.
Somewhere along the line, I got careless and shorted a live cap lead and popped one of those proprietary and obsolete chips on the tuner board - the PA1001-A. It was not fun finding another one to replace it with, and it turned into a very expensive lesson on the consequences of not paying attention.
If you're going to do it, do one at a time and test after each replacement, and be Very Careful around those chips.
I will look for your thread on the Tuner. I have collected (2) SX-780 part units in case the Proprietary chips go. Also have a SX-1050 for parts for my working SX-1050. You just never know...Thanks for the heads up...
