Yes, metal film is simply a better substrate. It's still a resistor.Can I replace carbon film resistor with a metal film resistor or vice versa of the same value and wattage?
Larry thanks a lot! I will follow your advice. I will update as I progress.Yep! Value and wattage the same. If it has a dual 1/4-1/2w rating for a 1/4w resistor, that is ok too. The one thing you'd want to do is put a crimp in the leads to raise them off the board slightly. Get them in the air and off the board cools them better. See IMG below......
Yes do the Faderlube on the push switches. POWER SUPPLY 1st. Raising the resistors above the board helps keep them cooler, and also keeps the board from cooking to char as there is now air flow (what little there is due to location and orientation.) Adding additional heatsinking to the plain heatsink is beneficial to reducing heat in the area.
Mark the Fixer years ago figured out the BIAS on the 939 is too high per the manual. PIONEER Engineers goofed on the Math (go figure.....College kids!!!?!??!!??!) 25ma is recommended bias for the 1010, 939, and 838. This will decrease the heat somewhat on the power supply.
This is from the SX-939 Schematic.......
I checked the bias it was set for 20 mV for both channels. I did not change it. Should I change to 25 mV?Yep! Value and wattage the same. If it has a dual 1/4-1/2w rating for a 1/4w resistor, that is ok too. The one thing you'd want to do is put a crimp in the leads to raise them off the board slightly. Get them in the air and off the board cools them better. See IMG below......
Larry: Do I need 8 ohm dummy load to set the DC offset?Yep! Value and wattage the same. If it has a dual 1/4-1/2w rating for a 1/4w resistor, that is ok too. The one thing you'd want to do is put a crimp in the leads to raise them off the board slightly. Get them in the air and off the board cools them better. See IMG below......
Thank you Larry!OFFSET NO. Set all controls to Center or OFF, NO SOURCE (Disconnect anything on Aux or Tape Mon to make sure)connected. Set Volume to Minimum, and Select AUX Function. Hook up the Meter, then turn on unit. Adjust per the manual.
The 8Ω dummy load is a left over artifact for the line people who did the initial alignment adjustments at the factory.
BIAS. Up to You. There may or may not be more distortion @ 20mv than 25mv(You might see it on a scope,, but probably wouldn't notice it by ear. If it was mine, I'd set it for 25mv and call it a day
Hi LarryThank you Larry!
Jeff: ThanksOthers might chime in but the typical method is to de-solder the pins on the board that have the wires wrapped on them, take lots of photos first.
Larry you are spot on! Thanks a lot and learning a lot from you! Meanwhile I recapped the power supply and heat is bit less. Next I will recap the protection board and will change the heat sink transistors in PS board. Do you think I need to change all the diodes and other capacitors in PS board?1st place I'd look is underneath the board for COLD solder joints around the Tone Switch, and Solder bridges in the areas of repair. Use a magnifying glass.
