Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Also look closely at the wires that connect to each of the circuit boards. They tend to break when you’re fussing about in there.
Next, measure the power supply voltages - refer you the service manual or past posts.
The SX-950 (and 850) are the sweet dpot of the xx50 Range - I resurrected a 950 from a parts unit and am using it in my bedroom system.
no it went in protect a lot than after I replaced the caps and adjusted the bious and mossfet it went into protection after 5 to 10 min instead of the first 1 to 2 min
then I recapped the power board and I got a popping crackling noise out of the right channel and it goes into protect after 15 -20 sec
