I might have access to a 3D printer here soon. I know how to use solid modelling software, and have designed an enclosure. If all goes well, I'll have one made soon. If not, then I'll probably get something off Amazon and modify it to work.
That I understand, but with everything connected? If so it seems a tad high.@PE9ZZ, I'm talking about the transformer voltages
My Philips (rebranded as PHILCO actually) CD player had both IC chips. The SAA7220P/A filter IC and the TDA1541A-R1. I can't remember now, but I think the two together in the DIY DAC sounded better than using the 7220/C that was provided. I wanted to go full vintage anyway, so that's what I did.
I'm also trying swaping the SAA7220P/C for a 7220P/A . Not sure it makes an audible difference.
@drp1003 I'm also trying swaping the SAA7220P/C for a 7220P/A . Not sure it makes an audible difference.
I'm sorry if this is a stupid question but you replaced 270uF caps with totally different value caps. How does that work?Yup, 4.7uf/50V polyester WIMAs.
Enjoy!
I have a couple of 10uf/50v Nichicon Muse in my component box, would they be a good replacement?
Are the Muse caps green? If they are, then I have used such caps before on another project. I have a pair of Nichicon MUSE 100uF 50v on the output of a CD player. In fact I was using them on the PHILCO (PHILIPS) CD player with the TDA chip before it died. Then I moved them over to another CD player. I also replaced the old OP-AMP as well with a new BB OPA2132. That CD player sounds amazing now.I'm sorry if this is a stupid question but you replaced 270uF caps with totally different value caps. How does that work?
I have a friend who is ready to sell his Marantz CD-80 with the TD1541 single crown. He lives out of state and I've never listened to it. I know it is well cared for and works as it should with excellent build quality. I'm wondering how it would compare with my Philips 680 with the R1 in it?
Thanks for your input. I know that there are many variables at play so it's impossible to just say, yes the a single crown sounds better than a R1. Thanks again, I'm going to check out your link.I'm fortunate to have an 'S1 and to my ears it offers a slight improvement in definition and detail over regular production TDA1541s. However, the difference can increase or decrease (or not at all) depending on system context + personal perception/listening bias. Most of my comparison was done in the context of my DIY nosTDA1541tube DAC.
Hi,
I have the same board as setup1 has. It came with a TDA1541 and SAA722OP/C installed. It sounds really good, but I have a TDA1541A and SAA722OP/B I got from an old CD.
Are they interchangeable? That is, can I change them without making any further change to the board?
