GGriswold
Thanks Selmerdave- I swapped the primary leads-the problem persists. Dang it. I may try disconnecting the feedback and see if that is part of the problem, but first double check the wiring of the first stage. In reading different articles- low screen voltage might cause it or driving the output tubes too hard- causing surges in the power supply which seems unlikely given the amount of filtering going on with this design.
I have found this guy to be pretty knowledgable- YouTube about motorboating-
I see you have a ROK- I have rebuilt about 3- have one someone gave me, but in rough shape... get to that after this. My nice Rondine has the Ashland motor.
I think your output transformer primary probably needs to be reversed for polarity, you're getting positive feedback rather than negative feedback.
