technics 103 switcher HELP needed
gummy
Hi All,
I am looking for any information on a Technics 103 switcher unit, I have one of these and need to know how to connect units to it, can anyone help me.
Thanks.
first one of those I have seen, made to play multiple amps/ speakers/ turntables/ and other sources, mix and match. I bet that was in a stereo shop and used to demo gear.
Those can be really handy. To be on the safe side I would want to know if the amplifier inputs and speaker outputs use a common ground.
Could be trouble for some amplifiers.
Other wise a very nice unit for connecting various piece of audio gear.
You just connect your various audio sources to the appropriate inputs and your speakers to the appropriate outputs.
You should just have to connect the input to the port on the back and then select that switch on the front and set an output to the desired area and select that as the output on the front.
Now, if only I could find one of those...
