technics 1200 series TTs?
Then there were ones like this:
I loved the shiny black plinth, but I always thought the gold was a little much. Reminded me of something like this:
I'm sure they don't sound any better, but you know how looks makes everything better...
Yeah. the gold is kinda added bling.. it does stand out... not much different than some other gear out there that has a lot of gold tones though..
so if a person found a good shape 1st ver. 1200 it would be just as good as the last mk.X ? Alot to read on kabusa website. thanks for the info.
The Mk2 is the one you want. Or newer. Were some valuable upgrades when the mk2 came out. The newer ones are all variations on that theme.
Agreed. There were some fairly big changes from the first edition, and the MKII.. I can't remember what they were though, but it was enough to avoid the first run.. I believe the quartz lock was one of the differences.
I run a 30 year old SL1300MKII which is essentially the same guts as the 1200 series with some semi-automatic features. The fact that the thing runs rock steady some 30 years later should be a testament to the Technics durability. My recommendation is if you go used just make sure the deck was used for home use and not DJ abuse.
thanks for the good follow on info re. mkII. If I find something that strikes my fancy I'll run it by ya all. Lotta DJ ones on local CL @ hi $$. Not interested.
I have had a few 1200's, and the key is as everyone said to get a mkII.
The M5G has some improvements over the mkII, especially the tonearm.
from the KAB website about the tonearm on the m5g
The arm differs in two ways. the wand is finished in satin titanium and features OFC copper wiring. This arm sounds more detailed in the upper harmonics. Which is what you would expect going from tin plated strands to OFC.
The 1200's are quite common, so you can afford to be choosy, and take your time.
I suggest going to a DJ store to check out a new one to compare used ones to if you have no experience with these tables.
if you are buying off the used market, these are the questions I ask.
1) does it include the dust cover
alot of the time, DJs lose them, or break them. also they remove them if they mount the tables in a road case.
no dust cover is a good indication of being gigged with
2) was it used for DJ-ing?
dj use is not inherently bad, depends on the type of use
3) was it used for gigging, or just at home?
gigging is the biggest abuse, avoid that
4) was it used for scratching?
i got one free once that was used for scratching, and the platter/spindle was warped. impossible to level correctly, 1/8"th difference in height front to back. tonearm in relation to platter, made for the cart not sitting right on the record, sounded awful
5) do you have the original technics headshell?
DJs usually lose them because they use the integrated DJ carts that have a headshell mount built in
6) are you the original owner
if not, then the seller cannot attest to the abuses it may have received from the previous owner
7) when was it bought?
very slight improvements over the years, and less time for dirt, dust, to settle in, and less likely to need any parts replaced.
the suspension feet tent to bottom out with age.
I just recently bought a pair of black mkII tables off a guy who used them as practice tables at home. they were never gigged with, nor were they used for scratching. just plain fader mixing.
tables were in excellent condition, with relatively no wear.
price was good.
Most important this is have a listen to it. See if you enjoy using it and listening to it. In the end, you are the one that has to end up loving it. At best, all we can do is point you in the right direction.
fully aware of that bigerik,. I'm no newbee to stuff audio so pretty much know kinds of things to look for, just as I did looking for collectable cars a few yrs ago. It's always good to hear what others think about things when you're not familiar with a certain brand, model or whathaveyou. With vintage audio stuff, sometimes I hit on something rite away while it can take time for what I'm looking for to turn up. I just like having the wealth of knowledge oon AK to look to.
Excellent!
You are all set then.
Just let us know how it goes and what you think of it. :)
