Embryos
The threads for the Aux weight werent damaged. The clip with the female threadswas bent out severely. seems like its not to big of a deal..as I have already removed the weight. The dustcover is in decent shape, it doesnt seem to have suffered damage during shipping. The stylus is functional, I have been using it actually. I am indeed in a hurry to change it, as it dug some deep gouges into the platter during shipping, and I understand I should not be using it AT ALL! The stylus did not break however! Cartridge is ok.have the threads for the aux weight been damaged inside the tonearm? I may have missed that. You only need that weight with some cartridges, and it shouldn't be hard to get another one. Check for play in the arm.
If you replace the arm, there are a number of wiring options -- different wires inside the arm, different ways to run through to the RCAs, different voltage regulators. Read around a little bit. You may find that you don't want to do an exact match. You may find that you can work with what you have if you want to save up for something beyond repairing everything to stock/ original.
Unless you are scratching, I would replace the platter mat.
For the dust cover, many recommend taking it off for listening purposes as it can easily pick up vibrations from the music. There are mods that can be done -- I think there are even Technics pieces -- so that you can use the dust cover to protect everything and have it as a removable piece. It really doesn't look to be in that bad of shape.
If your stylus came through without damage, that is a miracle. I would count on replacing the stylus. Hopefully the cartridge body made it through alright -- that will certainly save you a couple of dollars.
Aux weight/ platter mat/ stylus. None of these will require man hours from a tech. That is my first thought based on pictures, but there could be troubles lurking in the deep.
I dont think that I am going to change the tone arm, as I think I can live with the damage as it does not seem to be effecting the TT operation.. But beleive me, I would have rather paid the full$479, and received the MK5 in a secured status, than getting the $250 return, and dealing with all this! But I still consider myself fortunate as I do have a BEAUTIFUL TT!
