"Technics DJ table in NJ $50
The road case is worth the price of admission, even if the TT turns out to be a loser. That definitely looks to be a cheap DJ cart on there, but can't really tell, but I wouldn't expect too much from it.
Definitely worth the price if you're in the market, those turntables are very reliable, although I'd check it over fully before purchasing. As mentioned above, the case (and the felt mat) suggests that it might have been used for DJing. Make sure there is no play in the tonearm or platter bearings, and ensure that the tonearm moves smoothly across its entire range. If so, you're probably good to go.
