Technics SB-E100
doublevision
I found a pair on Technics SB-E100 for $200 but one woofer has been replaced and it doesn't sound great. What are my options for replacing then woofer or both and would it be worth it?
Technics are not a company best known for high end Hi-Fi, they’re more popularly regarded for their DJ decks. However, this interesting pair of speakers from the early ’80s are a good example of their really high end work. Utilising a 30cm conventional bass driver in a bass reflex enclosure, combined with two linear phase horns for mid and tweeter. Crossover setting can be tweaked manually using the rear control panel. These speakers are incredible efficient, due to the horns, with a sensitivity on paper of 95dB/W/m, making them ideal for very low output valve amps. The large bass cone/horn combination gives you the best of both worlds with deep down bass response (down to ~35Hz) and a lovely even frequency response from mid to very top end frequencies.
These speakers are rare and unusual and if sold today would probably cost nigh on £10K. Treat them well and your investment will most likely grow over the coming years.
£1419.00 (27 bids) Sold
Spares are hard to find but to retain the value of the speakers you should put in an original woofer.
Thats potentially a great price,and would be with the original woof.Actually still is.....Offer $125 and start looking for replacement.I have a few woofers from SB6000,but unsure of size. Let me compare to the SB-e 100's and I'll get back to you.If the woofer fits I'd help you out.
The Technics Linear Phase are total sleepers....fantastic speakers, from the 6000 on up.
Running a pair of SB-E 200s' with Sansui BA5K's.Just dreamy.
