jleon92f
Addicted Member
I recently bought a 1900 for $20. Absolutely new condition, complete with Empire cart. Like most of these models at this age, auto start doesn't work because it won't drop the arm. If you cue up and start it manually, the arm drops fine, and the auto return and shut off also work as expected. So fully auto is not an option.
Yours apparently has/had the same problem, and you posted some pics, but I'm not seeing the solution. Can you give more detail?
The picture of the cue cam, it was gummed up and not moving at all.
RR clean,and drop of oil took care of the cam. White plastic thing with the spring attached.
Thanks,
John.
