Tekton Owners Thread
The first few nights I ran them all night, but at very low volume, only because I wanted to sleep! Then I gave up on that and accepted the fact that I would just play them all day long at normal listening levels and try not judge what I was hearing for a week or more. That being said, they got better after weeks of listening. It took a longer time than I thought it would. I really believe the "placebo" or "getting used to it" effect was minimal. I was very aware of that and used several test baseline cuts over and over. My biggest change came with recordings of violins, string quartets, and the female human voice. Ah, and complex choral material.
Two other observations: 1) Because of my setup, I do mostly near-field listening. The speakers are about 7 feet apart and listening position is about 8 feet in front of them. (Though sometimes I listen at 15-20 feet which increases the effect of room reflections but develops bass extension). I found that a classic equalateral orientation with speakers toed in to fire directly at my ears was unbalanced. I have them standing practically straight out (parallel to the rear wall) with a very small toe-in. Play with your toe-in, I think that's a very important adjustment with the 7 tweeter array models like the Elektron. 2) I must also disclose there were a few other "mods" going on during that early period, some of which no doubt helped get me to where I am today. So the run-in context is not a pure-variable observation of course. I upgraded the speaker cables and interconnects during this period, and perhaps more importantly, replaced my primary preamp input tube from stock to a gorgeous Brimar NOS 6057 (12AX7 equivalent).
One other comment. Whenever these speakers sounds bad, I have found it is invariably the fault of the recording. They are very revealing. If the engineer has done his job well, then the soundstage and sonics are beautiful. If (as is more often the case) the recording is mediocre or poor, these speakers will present that to you exactly. They will not gloss over the imperfections like some of the British style speakers will. When I hear something nasty, I check it with high quality headphones tapping the music source upstream from the speakers and the amplifier. In other words, at the network streamer: and the problem is still there.
I am looking forward to (hopefully) hearing your reports as you move along.
Thanks, and I'll definitely give updates when they're in my home. I don't normally wish for time to pass quickly, it passes quickly enough as it is(sheesh, where did the last two years go?), but in this case I'll make an exception. I'm marking down March as a procurement date.
It’s my understanding the 7 driver array, at least on the DI’s, are one center tweeter and the 6 around it are different, they are used as mid tweets if there is such a thing. What looks to be mids are described as mid bass. I do know on the DI there is an obvious audible difference in the center driver in the array, I can’t confirm for other models.
I previously wrote about adding shims to the rear of the speaker to tilt them a bit down. I'm taking that back. I'm not sure what exactly the Jolida amp was doing, but since adding the Decware amp, I found just leaving the speakers level sounds best.
Decware! Lucky boy. What beautiful pieces they are. Aside from the 8 month wait, I am very happy with my Line Magnetic tube amp. That said, I have had fantasies of getting in the Decware line and pairing it with Eric's SET 2-10 speakers. Slap my hands.
You are correct. Eric has described this array in a number of videos. There is only one true tweeter: the center one. The other six are upper-mid range. The technologies of all his 7 way array speakers is supposedly the same. What changes, of course, are the other drivers. The Electron is the junior DI, and the "Impact Monitor" is the baby brother.
Just a note on break in; my Lore S (Seas driver) needed some time to break in (80 +/- hrs). Over that time the sound changed several times. The changes were pretty obvious - noting subtle about it.
OTOH, my Impacts (not Impact monitors) are the std pro drivers. They sounded fine out of the box & any break in was fairly subtle.
My point is, comparing break in of SE, BE or Pro speakers may not be valid. They are very different drivers.
It's a 17yr old model, not new. I was very curious about the hype and simplicity, but waiting that long on an unknown wasn't going to happen. I kept my eyes peeled for a used model and this one popped up. Problem is it's an "EX" modded unit with different transformers for higher impedance speakers, single drivers and/or simple crossovers. I really like the sound, but once you start getting into the high 80db's it runs out of power. I rarely listen that loud, so it's not a huge problem. I do plan to get on the list sometime.
I'm an absolute noob to tube amps. I love learning new anything when it comes to audio. I read the article written by the owner/creator of Decware explaining their origins and what tube amps are all about. Absolutely intriguing stuff there! I have no idea, or knowledge about electicity, ohms, impedence, etc., but it is so enjoyable to read about it. Not sure I'm ready to commit to said system/world, but maybe, eventually. Might have to try fitting in a tube preamp to my current SS integrated. Schiit may be a starting point, I don't know. Anyway, I really like what I'm reading in this forum, and so far it's a much nicer place than the week or so I perused audiogon.
Agreed. My post was specifically addressed to the owners of the Electron SE, which is what I own.
Yep.
Do we know which drivers are in the SE's? Are they Seas?
Tekton was criticized at one time for not using "exotic" drivers - looks like thats not an issue anymore.
I have a set of mLores which I like quite a bit. Lately, however, I've been thinking of an upgrade (an addition to the stable if you will). How much of an upgrade would the Lore Reference be over the mLores? Anything else I should be looking at that would be an upgrade but still have the same sort of sonic characteristics (I like the sound signature of the mLores) in the $1000-1500 range? I've thought about the Klipsch Heresy but never heard them. No real access here in the wastelands to listen to different speakers before buying.
I haven't designed the entire system in my head yet, but it will be a mix of analog and digital sources like my current setup. Amp will be solid state, maybe a newer class D depending.
Just my opinion, Klipsch are a love em or hate em sound. I don't like them. A friend lent me a pair of KG10 and then a pair of Heresy's to try out with 10 watt tube amp I had at the time. Loudest speaker I've had in my house, ever. However, they were very forward (screaming at you), really pump out lots of high frequency with little to no low end and were very fatiguing. Back then I didn't have my room treated so that may have played a part. The definitely needed a sub. I enjoyed a set of Sansui 1200's much better and Sansui speakers don't have the huge regard Klipsch does. Different strokes, some people love their sound. That said, picking a pair up and not liking them won't leave you stuck since there is always a demand for them so you shouldn't lose much trying a pair.
Sorry, can't give you any impression on the M Lore/Lore reference. I still have a pair of Lores and they get daily use with the tv setup. Only fault with the Lores is they worked better for me with a sub.
I've seen a lot of photos of Tekton speakers sitting on plinths, wooden or otherwise. Am wondering if these are homebuilt, or ready made? Any ideas on where to find similar bases?
I’ve had both speakers and the references are more detailed than the m lores. It kind of depends on your preference. What are you looking for? Personally, I think the m lore are more forgiving of bad recordings and for me that made them for fun to listen to.
Eric had a video where he compares the three lore models. If I recall he basically says the Lore sound more like the m lore (but bigger) than the references do. If I could have done it over I’d probably have kept the m lores or upgraded to the Lore as I like music that often needs some forgiveness. :) This is also why I don’t listen to everything on my main system.
Tekton does not make speaker stands that I'm aware of. Post a pic. Lets see what you're looking at.
Here's a couple of photos I "snagged" from two different classified sites. But you get the gist of by seeing it's just a board of wood or some other material. I was looking around the web and found what. might serve well, a maple cutting board 12"x16", sanded w/smooth rounded edges for around $25/ea. But, I'm sure there are other ideas, but I have no tools (router, saws, or the like) to create my own. Aesthetically, I like the way the plinths look.
View attachment 2435234 I made these using just a saw, hammer & screwdriver. The stands are on wheels as the Impacts are pretty heavy. I like the platforms you posted. Prolly help keep the speakers stable. The big ones can be a bit top heavy.
Nice work there, Bob! I'm working with really tight tolerances as far as building out from the base of the Electrons I have on order. I'll probably nix the whole idea, or go with the wood plinth, and place MagicSliders under them so I can adjust, and move, the speakers easily on our oak flooring. Or, just place the MagicSliders on the bottom of the Electrons, themselves. Thanks for sharing your handiwork!
The Electron SE's are not forgiving. But I'd rather have that. Yes, I'm more dependent on the recording engineering job. But when engineering have done their job it's sublime. Also, decrease the harm caused by bad recordings by "softening" the system balance slightly with British-style preamp tubes which made a huge difference. I try to leave the cables neutral (i.e. DH Silversonic Air Matrix and Straightwire Serenade 3).
Hi everyone. I am fairly new to AK and this is my first post to this thread. I just finished reading all 151 pages for the second time. It is great to have this much knowledge and experience available in one place. Many different roads taken but all arrive at the goal of incredible audio. I first discovered Tekton when researching some BIC America speakers. I had never heard of Tekton so I thought it was worth a look. That was about 8 months ago. Now I think I have read every review and article available and they seem to be just what I was looking for, based mainly on your posts.
I am almost ready to pull the trigger. Still figuring out which set. I plan of calling Eric before I order them. Probably going with the Double Impacts but Eric may have a better recommendation. I have zero experience with tubes so I will probably go the SS route. Currently using a Yamaha R-S202 2 channel receiver and, in my opinion, sounds pretty good. I was going to purchase an Emotiva amp and preamp but decided to get the Tektons first, see what that sounds like, then go from there.
Thanks for all of the information in this thread. It is a fun ride!!!
