I've
I have set up a couple of very nice listening rooms in basements for myself and others. Personally, I sort of hate how the purpose built sound panels look, and find that I can get good results with the strategic placement of furniture, plants, and "treatments" that have higher WAF and appearance factor. I always start with covering as much of the floor with rugs as possible. Wall to wall carpet is ideal (and is what we have in our otherwise-concrete basement. From there, I generally occupy corners with shelving or other storage to change the square-ish shape of the room a bit. In my basement, there isn't enough space for a ceiling fan, so that's where my biggest reflection issues originate, but sometimes you just have to live with what you have. For the sides, I have a few low shelves with plants on them (iron plants are especially effective at diffusing sound, in my experience, due to their thick leaves) but the will suffer if there is no natural light. For a while, I was just rotating a few plants between the area by the sliding glass door, and the areas that don't get much natural light. It's minimal work, my view is that I'm willing to take the 2 minutes every other week to move the plants if it means my wife is happy with how the room looks. It's not that hard. If you have even small windows, you can use plants VERY effectively to provide acoustic control. A google search for low-light indoor plants will give you plenty of options.
Other diffusion is provided by curio displays (at my house it's medals and race bibs and other stuff from our various competitions and races, as well as bike storage/display racks). These don't necessarily absorb reflections, but they'll do a reasonable job of diffusing the sound. Strategically placed floor or shelf lamps with acoustically inert shades can help, too. In addition to these more "Flat" control measures, I will usually try to place furniture along the walls to break up the flat surfaces as much as the function of the space will allow. I generally find that between the "masking"(i.e. putting lights, bikes, decorative elements, etc), furniture placement, and plant arrangements, I can get to a pretty good spot acoustically, and only then do I consider the possibility of using a couple of the foam pyramid panels (always hidden by something in front... either a plant or in our basement, a bike) to provide a last little bit of control. I really feel like the panels are the LAST resort, though. They are hard to keep clean of dust, and they make me feel like I'm in an experiment or some laboratory, rather than a relaxing space meant to be enjoyed. Plants, on the other hand, have ben proven to help lower blood pressure, improve indoor air quality, and make a space feel more inviting.
If you have the space available, I recommend a heavy curtain behind the seating position for rear reflections. This happens to work for us because of how we use our basement and the fact that it has a walk-out patio. Friends without walk out patios have used back walls for storage shelves concealed by heavy, reflection-controlling curtains, giving them both the storage they need for all the stuff we all keep in our basements, and the acoustic results they want, in a visually acceptable setup.
The last fraction of my two cents that I'll pitch is not to be afraid to set your system up off-angle. Symmetry often feels right, but it comes with a host of challenges. Block walls and concrete floors do not reduce those challenges. Thinking outside the box (pun intended) can be a good thing and can open up some control methods that you might not otherwise think of. You may not be able to move parallel walls, but you CAN often move yourself, and your gear within those walls.
My tektons seemed to be more tricky than other speakers when I had them in the concrete wall/floor basement we have, but I was able to make it work quite well without having to resort to ugly (IMO) diffusion panels, or covering everything in pyramid foam (which is also unsightly, in my opinion).
