Tekton Owners Thread
I posted this in my "Members' System" thread, but thought it might be useful here as well:
I wanted to post my impressions of the Teac AI-2000 with my Lore Reference. I'd been using a TPA3116 based chip amp--the SMSL SA-60--for the past 7 months now. I listen to mostly vinyl and had been using a Schiit Mani phono pre. I've been wanting less boxes, thus my choice of an integrated with a phono pre built in. The phono pre on the Teac has impressed me thus far. It's quiet and sounds much more balanced. Instruments sound more like instruments and I can hear the textures of drum skins and bass strings, etc. What I've found surprising about the amp so far is that it really likes to be turned up. That is, I feel like it sounds best when cranked up a bit--everything comes to life. The little TPA3116, by comparison, sounds more detailed at lower volume, but can't match the clean, effortless sound of the Teac when pushed. I think my quest for an integrated continues. If the Teac had a little more life at a more moderate volume, I'd likely keep it. My musical taste leans heavy toward small ensemble jazz, and the Teac seems more suited as an amp to really rock out with.
So, I've got a Brio-R on the way. I'm keeping the Teac around to listen to against the Brio-R. Will update again.
If you like small group jazz you should be looking at SET amps.
I know, I know. I'm actually thinking of Bottlehead kit. Any recommendations on amps or kits I should be looking at?
There are some nice SET amps on Audiogon
JE Labs 2a3 $875 or make offer
Yamamoto 2a3 $1700 or make offer ( my dream amp )
I also like the hand wired point to point Raphaelite 2a3 or 300B on Amazon
The Bowei 2a3 or 300B on the bay is one gorgeous amp but I know little else although a member here has one.
Bottlehead kits are getting more expensive everyday and on top of that you've got to build it. Best bet is used as they are relatively inexpensive ( homespun looks turn some folks off ). Love mine.
Update on the "odd suckout" I mentioned in my impressions:
When I was doing my impressions, I didn't mention anything about how Tool sounded. Tool is usually one of my go-to test bands because I love Tool and the music is pretty demanding of speakers with very particular tone, driving complex rhythm, and wide frequency range. There was something off, which I couldn't quite put my finger on. I attributed it to the slight suckout I detected in the upper midbass. Upon further listening, I finally realized that Justin Chancellor (bass guitar) was almost completely missing from some recordings. I had to figure out what was up.
I did some testing with tone sweeps and discovered a narrow but deep null at 110Hz. Not a just a suckout; complete silence. It was in the ideal sitting position about 8 feet from the center of the plane of the speakers and just shy of 4 feet off the ground. Move in any direction more than 2 feet and it disappeared.
So I played with the seating position and speaker position (seating more than speakers) and at that frequency the response was perfect moved forward 2 feet. Did some more testing and found a complete null at 98 Hz at that position. Same deal as before, very deep/narrow and localized to that one spot in 3D space.
Turns out my room is really terrible in a very odd way. I did some 3D standing wave calculations and I was unable to recreate the pattern of nulls in the room. When the speakers were arranged around the midpoint of the short wall, there was a null along that midpoint halfway between the floor and ceiling starting at 85 Hz 6 feet from the wall increasing to 130 Hz at 12 feet from the wall. It is continuous. It's like nothing I've ever seen before. Additionally, I never noticed it with my old speakers. I had a pair of PSB Amazing Alphas (the original from the early 90s) in there and nothing ever jumped out at me like that.
The solution was a wholesale revamp of the room layout. It's now asymmetrical with the speakers much closer together than I'd like for day-to-day sitting position, but at least frequency response is close to flat everywhere a person might sit. When I want to get really serious about listening to something, I can move the coffee table and put a chair right in the sweet spot. Listening from there is audio nirvana, so overall I'm pleased with the layout.
To sum up my findings, these speakers are VERY sensitive to the sonic behavior of the room. Keep that in mind when looking to buy. Not only are they quite large physically, but they'll need extra care with regards to placement in the room. They may be more forgiving of bass boominess close to the wall than a rear-ported design, but the way they excite the air in the room reveals nodes and nulls you may not have noticed before.
Interesting observations. I have noticed that the "sweet spot" is rather small with the Lore S but I attributed this to a nearfield environment (8 feet from the speakers). Maybe more to it...
Thanks for pointing me at these. Just curious, what are your thoughts on Decware amps?
Decware makes execllent amps but they don't make amps with DHT tubes.
These are the big bottle direct heated triodes like the 2a3 or 300B that are favored by many and have their own unique characteristics.
Thanks for the information. I'm still learning about tubes, which is part of the reason I haven't gone that route yet.
Update
Well just a quick update on the M-Lore system in the bedroom. I am running them wtih the Parasound Z-series(amp, cd, tuner and pre). The room is about 15 x 12 and I have them on the long wall centered about 7 feet apart tweeter to tweeter.
Nothing short of amazing! I listen to about 1/2 hour of music each night as I fall asleep and this is magic. The image spreads the whole width of the long wall and the dynamics and bass precense is incredible at low volume levels. It wil crank as well but I generally do have it lower.
I am so happy that I took the chance on the M-lores and now am considering a change for the main system as well. More research to be done!
"I listen ... each night as I fall asleep" Sounds like a great way to end the day. Glad it worked out. I have some room tuning to do yet - imaging not that great.
Im running an Antique Sound Labs Tulip 2a3 amp with my Lores..tried alot of combo's that all sounded good but this is a pretty sweet match.
The M-Lores are sweet. I LOVE mine. Everytime I sit down and listen to music, I ask myself, "Really, how much better could it get?"
So what are you using in your main system?
I'm seriously considering Lores or Mini-Lores based upon the convergence of my needs and published specifications. I prefer to hear a pair of speakers for reference, before any money changes hands. I don't know anyone in Austin who has such speakers. It would seem that more Tekton owners have positive things to say about the company than do not.
They'd be driven by a pair of Marantz Model 5 amplifiers, fed by a modified Dynaco PAS 2. It would be easier to name genres of music for which I care not than to list all that I like. The room is oddly-shaped at rougly 12' by 30', and is of pier and beam construction. Essentially, the whole house resonates like a speaker enclosure. I'm leaning towards the Lores due to room characteristics. I have a pair of JBL L-110s now, and am looking for an improvement.
So the only difference in the Lore and Lore V2.0 is the tweeter......Which tweeter is more desirable?
Are there any downsides to powering these with my NAD which is rated as 80wpc at 4 and 8ohms?
Are there any downsides to powering these with my NAD?
Only downside is that you'll probably have to deal with selling your Epos' shortly after. :D
I bet the NAD will sound great. I like your taste in gear... Nice system.
- Woody
