I know, I know. I'm actually thinking of Bottlehead kit. Any recommendations on amps or kits I should be looking at?
Decware makes execllent amps but they don't make amps with DHT tubes.
These are the big bottle direct heated triodes like the 2a3 or 300B that are favored by many and have their own unique characteristics.
Poutry, I asked a question in the tubes section which you chimed in on. http://www.audiokarma.org/forums/showthread.php?t=668324
After the recommendation of the paramours (I think) from you I decided I would build the paramounts. But as you mentioned a few posts ago here. The Bottlehead stuff seems to be getting really expensive. I have been thinking that I would be better off spending the money on used gear instead.
Here you recommend gear as inexpensive as $600 shipped new from china.
Should I take all this, in your opinion, that I should spend as much as I feel comfortable with buying quality used gear in 2A3 or 300B form to get what I'm looking for? I would consider the Yamamoto but the styling is not on cue with my liking. I could spend up to $2K but would be much happier at $1k and not have to save more to get there.
My plan now is to find retail places that I can hopefully go and listen.
I've got the Lores BTW
And thanks for your time.
I'm hoping you guys can help me. I put together my system solely on internet reviews. I had never heard anyone elses system until yesterday.
My set up is as follows
macbook > cambridge dac > decware csp2 pre > Aric audio KT88 tube amp > Lores.
After hearing the gentlemans stereo yesterday I can't help but notice that I feel my Lores are a bit too shrill (if that's the word) or high pitched for me. I brought my pre and amp to his house and tried it on both of his speakers to see what the differences in our 2 setups I might here.
His speakers were the Gallo 3.1s and as a back up pair he had the zu omens. I found the gallos to be more enjoyable. The Zu's had the same high tone I find to be less enjoyab
I'm wondering if I can suit these Lores more to my liking? On the amp end Im wondering if a tube change will help? The pre has 6922 for input tubes and I just ordered 6N1P's to try in there place. The KT88 has JJ 12AU7's. Is there a different tube I should try in there place? I know that I can use a 12AX7 in it's place, but I don't think that will help me.
I'll give Eric a call or email this week. I just wanted to reach out to you folks 1st.
Thanks
I am getting ready to pull the trigger on the Lores. I have the RITA-880 tube amp and will also try the speakers with an Integra 80.3 / Crown XLS 2000 combo.
Has anyone run their Lores with similar gear? If so, which combo did you prefer?
I just picked up a Coincident Dynamo SÈ to pair with my Lore Reference and the pairing is amazing. I've owned three coincident amps and the Dynamo is very easy to recommend :thmbsp:
Btw: I have also heard from reliable sources that the crown xls is legit. Before I got the Dynamo I almost pulled the trigger on the crown.
I'm wondering the same thing as you, Jeff. What's a good pre-amp, used or new, to pair with the Crown amp.
Just got off the phone with Eric. I ordered a pair of Enzos with the Clarity cap upgrade. Should have them by the end of the week. I currently have the Lores which I am quite happy with, but I recently upgraded my amp to the Marantz PM-11S3 and wanted to get a more refined speaker. I did a lot of research and after talking to Eric I feel the Enzos will fill the bill. Does anyone out there have any experience with the Enzos? Will the Clarity caps make a noticeable improvement? Thanks.
Bob
