Tekton Owners Thread
Woody, with your skills you should be building your own speakers.
Ha! I can handle grills and stuff. The woodwork is only with the help of my best friend guiding me through it all in his wood shop. But thanks for the compliment! I'll stick to drawing logos. :-)
- Woody
Frank, the back wall and one side wall they are built into the walls. The ceiling will have a track I can slide them back and forth a couple of feet. I might build a couple of free standing ones if I need it. One wall will have velvet curtains as will the door opening and there will be four 2'x2' floor to ceiling corner bass traps filled with Owens Corning 703. Steve Deckert of Decware supplied the diffuser plans and has been very helpful in designing the room.
Thanks mgb. I believe the diffusers are tuned for many different frequencies, each well is a differant depth.....hence all the cuts! I really don't know the science behind it, but I can follow a plan pretty well :) Finally finished the last ceiling diffuser today. Once I drywall and paint I'll cover the duct work with 2" thick acoustical foam. Then carpeting and moving the Double Impacts down there.
That's quite an undertaking, but I'm sure it will be totally worth it! Wish I could hear the Double Impacts in your new room!!! You're in for a treat! Now that I've sold the Maggies and ordered the Double Impacts, I'll have enough room in our library for them when they arrive, but they'll be a bit cramped...:D
Now you have to buy an amp from Steve
Lol. You're right Poultrygeist. I have his CD player on order and looks like I'll be picking up a torii Jr. amp this weekend from a local seller.
Anyone have input if the Lore Reference would overpower a 11 x 17 room? It's a dedicated audio room and I'm really intrigued with these speakers. I'm not a tube guy but prefer live recordings and jazz. Listening to "no quarter" right now - Jimmy and Robert unplugged. Thanks.
I don't believe so. This what drove me to buy the Lore Reference rather than the larger Lore's, Enzo's etc, my room is a similar overall size to yours at 13 x 13.5, and even given the 'mid tower' size, they do still 'appear' fairly large, mostly due to width and depth, not height. However, due in part to their high sensitivity they play very well at low volume and have a really nice clean crisp sound with just enough low end to play on their own without a sub. Don't forget also since they are front ported they can be place very close to the front wall. This will reinforce the bass so experimenting just how close or far from the wall is key.
Will the speakers in your room be placed on the short wall or the long wall? Where is your MLP/PLP in regards to the walls and speakers? I also see you have plenty of vintage gear, i think these Lores sound fantastic with vintage amps. I have an old Kenwood integrated (the one in my sig) that i fire up once in while, it gives a slightly warmer and fuller sound than my other gear but it is far from perfect, really needs to be recapped. I would love to hear your thoughts/opinions about the vintage gear you have, i've been eying Sansui's lately myself.
Anyways, for the ridiculously low price of the Lore Reference, they are a fantastic speaker.
Guys, not sure what all of you are using for spikes, feet etc on your solid floors (excluding carpet), but i recently came across these industrial rubber sound isolation feet made by JW Winco that may be of some use to you all as well. My old New England home has soft pine floors that spikes sink into like butter, so those are of no use. I've tried spikes on discs but they are just not stable enough, especially since I move my speakers often. Anyways, the rubber feet from JW Winco are the proper thread for the Tektons (1/4 20) and are available in a few different sizes. For my purposes, not only do i use these feet, which by the way, grip the floor like a mofo, but i also then put heavy duty 1" round felt pads (Everbilt brand at Home depot) under them which makes moving around and adjusting very easy. Also, for those with Lore models or others and wish to point the tweeters up more towards ear level, i recently purchased more of these feet but in the next taller size up. I was using .5" high (1" round) feet on all corners, now i have .5" rear and .75" in the front corners. It's a very mild angle and when using a laser pointer i can tell the are perfectly angled to my ear level. Of course the further you are sitting back the greater the height of the angle would be. They also have .25" height feet, so you could use the .25" in the rear and .5" in front as well. You can buy them direct from JW Winco or on Amazon.
index.php
Side view:
index.php
.75"
https://www.amazon.com/gp/product/B00F7E9VU4/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
.5"
https://www.amazon.com/gp/product/B00F7E9M30/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
index.php
Side view:
index.php
.75"
.5"
Hi Msas,
Do you know if all Tekton speakers use 1/4-20 thread? I'm considering these for my Double Impacts, which will be on a tile floor, but I would like some mobility. Thx!
I'm pretty certain they are, i've read others using 1/4-20 also. You could give Eric a quick call if need be, would be faster than email. I can't imagine though why he would use different threads for different speakers. Keep in mind you'll need some felt pads on the bottom for them to slide easily.
Thanks! Good point on the felt pads. Hopefully, the 106 lbs of the DIs won't pull the pads off when attempting to move them.
The double impacts are 1/4-20 threads. I'm using Mapleshades heavy feet brass carpet spikes but would definitely use those JW Winco feet if I had hardwood floors.
If you are concerned about buying the wrong size, 1/4-20 is a common thread. You could buy a bolt at your local hardware store to see if it screws in properly.
Good point, Chris. I have used 1/4-20 bolts before, so I'm familiar with the size. I just want to make sure I have all the "pieces" together by the time Eric has built and shipped my speaker order! ;)
With tweeters mounted below the driver it's a good idea to give them a back tilt so they're firing at your ears rather than your belt buckle. The Home Depot lag bolts come in a variety of lengths and with the correct thread to replace floor spikes. Plastic caps keep them from marring hard floors or you can grind the lag bolts down and make spikes in any length.
