Thanks, Poultry! I may go this route as it's inexpensive and readily available, although I'm liking the threaded stud glider options available through Herbie's Audio Lab. The wider base would seem to be better for ease of mobility. For those interested, here's the link:Lag bolts come in all sizes and lengths ( either hex head or round ) but you would only want the ones that are threaded on the ends. That way the threads won't show.
It's a good idea to take a factory spike with you to the hardware store so you can get the correct lag bolt thread pattern and size.
I covered the heads of the bolts ( floor end ) with plastic bolt caps which you can also find in the hardware section.
If you wanted to make spikes out of lag bolts all you'd need is a cheap bench grinder from Northern Tool and a way to secure it while grinding down the head.
I would bother with a tile under the Tektons as they are not bottom ported like the Zu's.
Thank Dave, I think it may have been one of your posts that led me to them.I use the Herbie's Glider Feet with my Lores. The speakers stay were you put them but are easy to move when needed. 1/4 x 20 fit my Lores.
-Dave
Thank Dave, I think it may have been one of your posts that led me to them.By the way, what stud length did you choose for your Lores?
You can buy disc gliders at Home Depot
Yes, but they don't cost $16.34 each.
Hi Poultry, I looked through Home Depot's site, but didn't find any gliders with 1/4-20 threads that looked sturdy enough for 100 lbs speakers. I saw some options on Amazon, but they weren't much cheaper than the ones at Herbie's. Regardless, I've probably got plenty of time to make a choice. Unless Eric's really ramped up production, I'm guessing I'll need to wait at least a couple of months before he gets to my pair.You can buy disc gliders at Home Depot
Thx Woody, the reviews seem to be very good with their products. I'm mostly concerned with safety when trying to slide tall and heavy speakers on a ceramic tile floor across grout lines.Herbies Lab products are very good and work as advertised. The gliders have their DB neutralizer product in them and help with isolation while decoupling from the floor. They aren't cheap, but I've always been pleased with my Herbies products.
- Woody
So, I would assume that to use these I would need to install the spikes and center them over the indent. If this is stable when sliding over short distances, it would be my preferred way to go!HD disc gliders
Actually, I think you were implying using the lag bolt in the indent, correct?So, I would assume that to use these I would need to install the spikes and center them over the indent. If this is stable when sliding over short distances, it would be my preferred way to go!
And this why I don't typically post in the equipment threads.
-Dave
Are you saying that Herbie adds some $125.00 to the value of every speaker?
