Last night I began my exploration with the help of ChatGPT. Then I came over here to get real life advice from actual, you know, people. AI can be useful but one has to be careful because it can also be way off base.
This morning I fed your recommendations to it and it spit out what follows.
It had some of that information from last night, which I didn't think to post here. Apologies is that should have been posted.
Now that I’ve seen all three pages, the comments actually clarify the situation quite a bit.
The biggest change to my view is the
cartridge. I would
not replace it just because it’s old. Your Realistic R1000E is a Shure-made cartridge from the M75/M91 family, and there’s longstanding documentation that these Realistic/Shure bodies can take compatible N75/N91-family styli. They’re genuinely good vintage moving-magnet cartridges, not junk. That makes Malden’s basic point sound:
the cartridge body is worth keeping; the stylus is where the quality decision belongs.
That also means the fellow suggesting an
AT-VM95ML isn’t giving bad advice, but he’s suggesting a different strategy. The VM95ML is an excellent modern cartridge. It would essentially say, “Forget the vintage Shure ecosystem; put a known modern cartridge on it and be done.” Perfectly reasonable, but I think it’s
premature. You already own a potentially very good cartridge body, so I’d find out what it can do first.
On the
turntable itself, the forum is leaning more favorably than the person who called it merely “modest entry level.” There’s good evidence that this is from the CEC-built family of Japanese belt-drive tables, and the resemblance to the Marantz 6025 is real. The Marantz 6025 service literature shows a four-pole synchronous motor, belt drive and published wow/flutter of 0.07%, while a contemporary directory specifically lists the
Rotel RP-1100Q as a hysteresis-synchronous belt drive with wow/flutter under
0.2% WRMS. I would
not quite say the Rotel is literally identical to the Marantz 6025 yet, because we don’t have enough evidence to establish that. Same general CEC family/platform is much safer.
The
wow discussion is where several forum posters are overinterpreting your first number. They saw “0.34%” and understandably reacted as though that were a properly measured WRMS specification. But your later experiments showed the app giving you
0.19, 0.42, 0.31, 0.31 and 0.26% while the actual average speed barely moved—roughly 33.23–33.29 RPM. That makes it very difficult to regard the phone’s absolute wow number as a reliable measurement. One forum member correctly zeroed in on phone centering as a source of error. Your first post accurately reported what happened—the motor unexpectedly worked and the phone gave you 33.29/.34.
And that brings us to the
belt. I would specifically
not replace the belt now. The seller says it was recently replaced, the turntable starts normally, it ran silently for an extended period, and your average speed is extremely close. A new belt of wildly wrong dimensions would normally give us some evidence—slipping, poor startup, instability, visibly improper fit, or a meaningful speed error. You currently have none of those.
Could the belt nevertheless be slightly wrong and contribute to wow? Sure. We haven't proved otherwise. But replacing a recently installed belt on speculation could actually make matters worse.
The belt is currently way down my suspect list.
So if this were sitting in front of me, my course would be:
- Leave the belt alone.
- Keep the Realistic/Shure cartridge.
- Clean the existing stylus when your brush arrives.
- Set up the arm properly before playing anything—tracking force and anti-skate are important.
- Buy a couple of $1 records and actually listen to the thing.
- If you decide vinyl is something you want to pursue, then buy a good stylus for the Realistic/Shure rather than a cheap Amazon replacement.
And on that last point, I’ve changed my advice somewhat after reading these comments and checking the cartridge lineage. Yesterday, the $25-ish Amazon stylus seemed like a sensible replacement.
I would no longer buy that as your long-term stylus. Not because it necessarily won't work, but because now we know the cartridge body itself is good enough to justify something better. If you're only playing $1 records while experimenting, keep the existing stylus for the moment. If you decide, “Yes, I like this and I'm going to build a record collection,”
then a quality JICO becomes much easier to justify.
There’s also a nice middle position between a $25 no-name needle and an expensive top-of-the-line stylus. We don't have to jump straight to the most expensive JICO Malden linked. We can work out
exactly which stylus fits your particular R1000E, what each tip profile buys you, and which price point makes sense for this Rotel. That’s where I think we should go next.
Overall, though?
The forum comments make me more positive about your $25 purchase. The emerging picture is not “cheap turntable that happens to run.” It’s
a respectable CEC-built vintage deck with a worthwhile vintage Shure-family cartridge, apparently recently serviced, running quietly and at very nearly correct speed. The big remaining unknown is not the motor or even the belt. It’s
how good that yellow aftermarket stylus actually is.
