Is that what comb filtering looks like on a graph?
http://www.jblpro.com/pub/technote/fat_wht.pdf
but... how do they SOUND? :tresbon: or
Used as normal speakers, in free space, they're basically "neutral," as designed, but not all that flat by contemporary standards, as the measurements show. With this model, it's important to have the grilles in place. There's a reason that tweeter opening is just such a small hole up front.
As mentioned above, they could get bass heavy with boundary reinforcement. They're beamy in the VHF, but at least they're not "out of control" like some others I have measured recently. They do not image well; I'm still working with that. Judging from the reactions of visitors to ZilchLab, I'm becoming convinced that not many "listeners" have actually experienced the pleasure of decent imaging.
Stacked, the issues are clear. We have two tweeters displaced horizontally interfering with each other with horizontal movement, and two woofers playing well into the upper midrange displaced vertically interfering with each other with vertical movement. There's only one point in space where the reproduction is as accurate as playing a single pair normally.
How about stacked with both speakers upright instead of the top one inverted? Measured about 5 feet away centered.
Then, you've got the tweeters displaced more vertically, and centered between them is not centered between the woofers which, again, are playing substantially into the upper midrange. As Ray has previously pointed out, that alignment is less sensitive to horizontal movement, but more likely to be "wrong" everywhere. Separating the tweeters is a worse idea.
From the tech note I linked at the beginning of this post:
When two sound sources producing identical program are displaced relative to
each other, they will combine to produce a unique interference pattern that
depends on the observer's location. The interference pattern is a result of the
different arrival times from the two sources.
There are rational approaches to stacking. Slapping Advents (or any other speakers, for that matter,) on top of or beside one other and playing them full range is not among them....
