Are you talking about some sort of formal blind testing with multiple participants? Have any links?
In some cases, yes, in others just the usual audiophile thing, with groups that vary from two or three to a dozen or so. No links as these were not paper-worthy.
I was present for a few, but not for most that have occurred as they have been scattered to several states and several countries. Sota has also performed its own testing, but I can't speak for them in outlining the details of their evaluations, but it did include quite a bit of comparative listening sessions versus a number of different phono stages.
In fact, it was only after those tests that they decided to adopt the design for their own and proceed with production of two models based on it.
Incidentally, I have only an academic interest in this, and the results- pro or con- are equally valuable. Essentially the goal was to test the applicability, if you will, of the extant metrics for audiophile quality by implementing a design that satisfies them all, but is, in a sense, the anti-Pass and Pro-Putseys approach, and that creates an explicitly neutral design. A phono stage was a good test bed as the high gain requirements tax the ability of the design to meet the extremely demanding specifications needed to satisfy the metrics.
Even then there are those that claim that the sound is improved by, for example, changing the power cord, which is something that the unit was explicitly designed not be sensitive to, so audiophiles will always do their tweaks, apparently. Sota also insisted on changing from a SMPS to a linear supply to satisfy audiophile sensibilities.
The architecture, to my knowledge, is unique in a production environment, and is explicitly structured to make the best use of the available high performance opamps.
