wyn palmer
Addicted Member
Yes.So the suggested changes will flatten out the frequency response in audio band but b2 still could benefit from a hf rf interference filter?
Baby steps for this DR guy.
Using opa1612s will extend the bandwidth to several MHz and extra roll off should be provided, in my opinion.
Honest question; does the Neumann design cause problems? I don’t know anything about design but wondering why Jim would use it if it was a bad idea?
What happens when you make your suggestions as to the performance of the bugle2?
DR
The simulations agree with this,
the bump at the end is the "Neumann pole" which assumes a characteristic for the lathe cut off filter (order, type and frequency) which is rarely followed in practice and is usually chosen to not be implemented these days- for good reason. I don't include it.
However, implementing the 75us has to take into account the shunt resistance that is R12 plus R13 in series, and is actually maximally flat with a value of c. 8.82k (NOT 7.5k) with the other Rs nominal.
R11 is shorted or swapped with a jumper. Same thing.Just to clarify, is the second graph with R10 = 8.82K and R11 shorted or swapped for a jumper?
As I tried to point out the effective resistor in series with the shunt cap is NOT the 8.82K but the 8.82k in parallel with 47.5k in series with 332ohms.Thanks. The reason I ask is based on my RIAA calcs, 8.82K with 10nf works out to 1,804Hz for f3.
Baxandall used a similar approach for the 75us time constant with 750 ohm and 100nf.
I think I'm following you now thank you.As I tried to point out the effective resistor in series with the shunt cap is NOT the 8.82K but the 8.82k in parallel with 47.5k in series with 332ohms.
Are you a EE? Are you familiar with the concept of superposition?
That's why the sims turn out to be correct.
I prefer a very, very different approach as I have a different idea of what "optimum" means than Baxandall.Thanks. The reason I ask is based on my RIAA calcs, 8.82K with 10nf works out to 1,804Hz for f3.
I'm not an EE. Just a guy who studied way too many phono preamp schematics during quarantine. I guess I found it more interesting than baking sour dough bread or watching Tiger King.
I'll definitely read up on superpostion. Thanks!
All it really means is that there are, in effect, two voltage sources (well, actually three as the branch with the cap to ground is also effectively a voltage source) that combine at a node, each of which has its own output impedance. As a result the output impedances are in parallel and the output voltage is the combination of the two sources each of which is ratiod by the source impedances. One just happens to be zero volts, which makes it easy.I think I'm following you now thank you.
https://www.dropbox.com/s/qlqwoalnysuxysb/whitepaper (2).pdf?dl=0I think I'm following you now thank you.
I recently picked up an AudioWind A300 clone of the Bugle which I have yet to hook up and try.Is anyone going to try the mods on the B2? I’m sure hoping that someone has one that are willing to try. Obviously it’s going to take a minute but it’s possible that some have an old Bugle2 laying around and perhaps a few caps too.
From however my ears are tricked, I really believe that c5 with silver mica, and perhaps a Vishay 1822 220nF at c4? will make some heard changes. Dare I mention adding the Vishay 10nF 1837 in parallel at c4? I don’t want anyone’s blood pressure to get as bad as mine.
I don’t know what outcome will happen with the stock op amps and c4, c5, c6 changes. I am partial to not doing anything much else to c6 other than a Vishay 1822. Oranda did the XO swap there I believe and if I remember correctly, wasn’t a bad idea but I defer to him for proper reporting.
Looking forward to those who try some of suggestions are whatever they find.
DR
I'll eventually mod and report back but it could take awhile. Too many other projects in the mix right now
One other thing, the WP design- which uses these metrics to guide the design choices- has been extensively tested in comparative listening sessions versus many different phono stages, including some extremely expensive ones, and has performed well, generally being preferred- at least by those who are not wedded to tube designs where the odds are 50-50 at best. It seems that having extremely tight RIAA compliance and distortion that is below the audibility threshold over the entire audio range together with very low noise does seem to provide a neutral presentation and extremely good retrieval of detail without false brightness.
