I'll try phones, but my computer system is pretty good. Apple with a Audient interface feeding Neumann powered monitors. I'll make note of what to listen for. Thanks.gnuyork: Try 'phones or stream to a "real" audio lash up. What happens in proper mono-ized mono is that uncorrelated noise gets folded into the centered music signal and thereby is not attended to...rather than taking on a life of its own in the left and right channels.
I have a bunch of mono recordings. For me, mono is to music what black and white is for photography. They are both, in a real way, "abstract art" by definition, only music less so, because of how acoustics work. Often, people don't even know they are listening to a mono recording. You ALWAYS know when a photo is black and white.I'll try phones, but my computer system is pretty good. Apple with a Audient interface feeding Neumann powered monitors. I'll make note of what to listen for. Thanks.
btw, my preamp inn my vinyl system has a mono switch...and I think I only have one or two mono albums anyway (good ones though).
What specific distortion are you referring to?Not the same as eliminating the distortions from the input signal in the first place by selecting mono for mono records.
Thanks! Now I know why my pre-amp has not only a mono switch, but left only mono and right only mono. I need to try it out on a mono recording.Refer to @tubewade 's reply #10 on the previous page.
On a scope you can see the distortion artifacts playing a mono record in stereo. In mono, these are virtually eliminated.
Thanks! Now I know why my pre-amp has not only a mono switch, but left only mono and right only mono. I need to try it out on a mono recording.![]()
It's an opportunity to use phase cancellation to dramatically reduce surface noise and/or rumble on some monaural records. For stereo playback the horizontal motion of the stylus is the sum channel L+R, while the vertical motion is the difference channel L-R. During monaural playback summing the two channels adds the horizontal movement (L+R) and cancels the vertical movement (L-R) which is rumble and noise/distortion. The cancellation can be 25 to 30 dB, so quite effective. It makes a lot of difference on some records, especially if they have seen some damage or were lacquered on rough equipment. On later records in good shape it might make very little difference.
If you doubt that summing electrically can make much difference I'd suggest you swap the polarity of one channel of your phono cartridge at the pins, then play a monaural record with the mono switch engaged and see what you think.
Ok, so I have Dave Brubeck MONO playing now. Yes, the noise reduction effect is pretty cool. As 62caddy pointed out above, cancellation seems to need to be done early in the transduction cycle (with the MONO button), by the time the STEREO mono signals come to my ears, the noise does not cancel like I thought it would (based on how transaural acoustic crosstalk cancellation is supposed to work).
This Columbia High Fidelity recording is scientifically designed to play with the highest quality of reprodudtion on the phonograph of your choice, new or old. If you are the owner of a new stereophonic system, the record will play with even more brilliant true-to-life fidelity.
Similar to what's on my Hitachi HCA 7500.A little off topic but I'm repairing a Pioneer SA-800 right now. It has an entire knob devoted to the issue of listening to mono LP giving the choice of either channel independent or both summed:
From the MONO Brubeck "Time Out" record jacket (CL1397) :
That picture implies both channels are equally affected, but tracking imperfections could cause them to cancel each other out. Sounds like the solution is to listen to the signal from one channel or the other, but not both.Ok, so I have Dave Brubeck MONO playing now. Yes, the noise reduction effect is pretty cool. As 62caddy pointed out above, cancellation seems to need to be done early in the transduction cycle (with the MONO button), by the time the STEREO mono signals come to my ears, the noise does not cancel like I thought it would (based on how transaural acoustic crosstalk cancellation is supposed to work).
I listened to both on my good headphones. The only difference is that the surface noise is in stereo. Over speakers it wouldn't matter at all and it doesn't matter much with headphones.
