I finally had some time to draw up a schematic for the regulator circuits I designed for my MC 240. It warrants little discussion except to again suggest that it is quite simple in design, while extremely effective for the application. Highlights include:
1. Both the B+ and Bias regulators are based on the use of a IXCP10M45S three terminal constant current device, which are provided in a standard TO-220 package. In the B+ regulator, this device does not require any heat sinking, while in the Bias regulator, I use a simple little clip on heat sink since the device dissipates about 0.25 watt in that application.
2. The Pass element for the B+ regulator is an FQP9N30C power MOSFET, which is a 135 watt, 9A, 500 volt device also in a TO-220 package, and well over rated for the application. It is a common N-Channel Enhancement mode device, but really, any such device with similar capabilities could be used. Just make sure that whatever device is used includes an internal reverse polarity protection diode between the Drain and Source terminals -- otherwise, an external one will be required.
3. A small supplemental power supply is used in the B+ regulator design, allowing there to be enough extra voltage to maintain the constant current device's proper operation even when the B+ supply has been pulled down to its lowest level when maximum power output is being produced in both channels. This feature is what allows the the combination of the B+ regulator and new precision 1Ω current measuring resistors to collectively introduce less than a one volt drop in supply voltage under full power conditions, versus that produced without these components in place.
Because the supplemental supply need only supply a couple of mA during operation, the smallest of transformers can be used. I actually broke open and used the transformer out of an old 9 vac 250 ma wall wart. Unloaded, the secondary of this transformer provided about 12 vac, which is perfect for developing the extra voltage needed when used with the voltage doubler rectifier circuit shown.
4. Because the Bias Regulator is only regulating the voltage supplied to the grids of the driver tubes, no current is drawn in that circuit, and the constant current device can directly provide the bias voltage needed. The bias control is arranged to be a fail safe design, so that if the wiper of the control should ever lift from its track internally, bias voltage to the output tubes will increase, rather than decrease.
5. In the amplifier chassis, the only modifications include:
A. Adding the 1Ω current monitoring resistors in the red OPT lead of each channel.
B. Breaking the B+ and Bias supply connections to route them over to and through the Constant Voltage Output Connections socket.
C. Adding a 470K 1 watt resistor across C25A/C26A to provide a bleeder path for the power supply caps should the amplifier ever be turned on without either the regulator or dummy plug inserted. This resistor draws an insignificant amount of current in operation (<1 mA), and will safely discharge the power supply caps if that scenario ever occurs. If it does occur, the amplifier will simply not operate, and no damage will be done to any of the tubes or components.
So modified, with the regulator plugged in, all of the high power transient clipping is completely eliminated, allowing a full 110 watts of power (55 X 2) to be instantly available on demand, with even less output tube dissipation, while still meeting original McIntosh performance specifications. And, these benefits can be achieved whether using vintage or modern production output tubes, thanks to the adjustable bias and current measuring facilities now provided.
Or, simply disconnect the regulator plug and insert the dummy plug, where for all intents and purposes, the original design of the amplifier is then fully back in place, other than for the inclusion of the 1Ω current monitoring resistors, which are a beneficial modification to include, whether the regulators are added or not.
The topology of the regulators is such that with appropriate adjustments, they would likely work well with any of the vintage Mac amplifiers of similar design, be they stereo or mono units. I leave those efforts up to any who might be so interested in pursuing that end.
Dave
Below: Inside the box, the simplicity of the circuit can readily be seen. The blue trim pot is located on the B+ regulator board, and is adjusted to produce a 405 vdc output from the regulator. The separate bias regulator board is almost dwarfed by the clipon heat sink used for the Constant Current regulator on that board. The little wall wart transformer is more than adequate for the job :
Below: On the B+ regulator board, most of the space is taken up by the small supplimental power supply used in the design. The Constant Current regulator needs no heat sinking:
Below: The pass MOSFET is located well down inside one well of the dual device heatsink used, providing protection from accidental contact with the tab of the device, since it sees 460 volts in operation. The heatsink gets only slightly warm after hours of operation:
Below: On the side is a power indicator light to verify the little supplimental supply is operating, and the bias adjustment to set the output of the bias regulator circuit for the correct current draw of each complete output section in the amplifier. The adjustment is supplied with a locking nut so the adjustment cannot be accidentally moved once set:
Below: Remembering that this was entirely a junk box project, the box housing the regulator circuits originally housed a transistorized preamp used in a rack that made up a 60's vacuum tube powered Carillon system. The dual heat sink assembly was extracted long ago from a quickly discarded germanium powered receiver, both of whose driver transformers (among other things) had bit the dust. The small AC plug appearing at the end of the cable plugs into the 240's auxillary AC power socket under the repurposed Constant Voltage Output connections socket, and powers the small supplimental supply for the B+ regulator:
Below: Schematic of the two regulators:
