6550 Version Now Complete
The new driver stage for the 6550 version has been installed now, with the NFB network adjusted for the same level of feedback that the original and modified version of the 8417 amplifier employs (17 db), as well as both the high and low frequency stability networks adjusted for similar results as well. Both the modified 8417 amplifier, and the new 6550 amplifier are utterly stable into any kind of load, with no amount of capacitance only load causing any tendency towards HF oscillation, while DC pulses produce very fast settling. Both of these qualities relate directly to reproduced sound, producing a cleanliness of HF sound without any shrillness, and tight bass that is well defined.
On the test bench, both amplifiers perform nearly identically, with the primary exception of input sensitivity. Since the original, common, screen grid supply and filtering circuit is still employed, each channel tends to regulate the other when each channel is driven individually. Under these conditions, each channel individually has a power bandwidth of 30 Hz, to 10 kHz at a sustained 125 watts RMS, and a power bandwidth of 20 Hz to 20 kHz at 70 watts RMS. At the 125 watt power level, distortion at 1 kHz is under 1%, with each channel producing about .8% THD at 100 watts RMS. The frequency response of the modified 8417 channel has previously been clocked at -1 DB @ 50kHz, while the 6550 channel can do a little better at -1 DB @ 60 kHz. Sensitivity wise, while the modified 8417 amplifier requires 1.75 vac to produce 100 Watts RMS output, the 6550 amplifier only requires half that amount at .87 vac. The target was to get this figure to around 1 volt, since that is more in keeping for equipment built for consumer oriented use, rather than the nearly 2 volt requirement this amplifier had for its original industrial intended use. Both channels are acceptably quiet on my 101 db efficient speakers, with most residual noise coming from the close proximity of power and output transformers on a chassis with a rather small foot print.
In the listening room, both channels sound identical for all intents and purposes. Both are incredibly responsive, with endless amounts of power on tap. It is really not possible to faze these amplifiers, as they laugh at the most complex recorded passages. On pipe organ music, the lowest bass notes are reproduced with great authority, with zero sense of work or strain. I ran the amplifier for 10 hours straight with the power transformer running very cool to the touch, and output tube bias remaining quite stable in both channels over the period.
Which channel is better? Tough question. Frankly, they're so close I would say that if you're so inclined, I'd build whichever is the least expensive for you to build. That will likely be determined based on your particular tube situation, or which tube you tend to favor most.
All that remains at this point then is to investigate the installation of EFB. It was hoped that possibly the 6550 version might not need EFB, with the inherently better screen efficiency those tubes have over the 8417, but that didn't appear to pan out in this case. As is, both amplifiers are very acceptable, with measured and sonic results running way, way ahead of the original amplifier as received.
A few pics to show where things currently are:
1. The 6550 channel is complete now, completing the original task of modifying the unit for stereo operation, incorporating a modified 8417 channel re-purposed for best home use performance, and providing a 6550 version to effect the same goals with more commonly available tubes.
2. A 10 kHz square wave from the 6550 version is virtually indistinguishable from that produced by the modified 8417 channel. Both have an acceptably fast rise time, quickly settling down to a very flat wave top, showing the very high degree of stability present.
3. Getting set up and warmed up in the listening room. This shot again shows the relative size of the two different sets of output tubes.
4. All wired up, ready to go. The clip lead attached to the screw at the bottom of the pic is a separate safety ground lead attached to the preamplifier. With this kind of power on tap, the last thing you want is a couple of hundred watts of hum blowing your ears and your speakers to kingdom come. This amplifier is definitely not in Kansas anymore.....
5. Another piece currently passing through the lab -- a Fisher 400 CX-2 stereo preamp is a nice mate for the Bogen. Together, the two made for many hours of some very enjoyable and effortless music.
So, with everything else complete now, EFB is the last stop of the last step of this project. It will require some reworking of the new bias supply installed, since at the time, a 6550 version of this amplifier was not being pursued. Now that it has been, it will require a slightly higher bias voltage for the EFB circuit to properly control 6550 tubes, in addition to the 8417s.
A bit of a break, but with a little luck, this project should be all wrapped up in another week or so. In the mean time, I should be able to post an updated version of the modified 8417 schematic, as well as publish the 6550 version schematic as well. The power supply schematic will be published after the EFB work has been finished.
Dave
