Now that I've set the stage, I unboxed the Bogen and for the most part, it arrived in the same state that it left here. Dave had mentioned a couple minor imperfections that appeared during the build process, but they are, quite frankly, inconsequential. After unpacking, I unplugged the Maggie and plugged in the new Bogen. I put my probes in the test jacks and fired it up. My only initial disappointment was the amount of hum! Dave had mentioned a certain amount of hum would be present due to the design of the tranformers. But this was more than I expected. After some thought as to what Dave had mentioned in his thread, I changed out the input RCA's for a better shielded pair. Viola, hum gone. The original jacks on the amp are located very close together and do no allow for very large plugs, so I may have to replace those and separate them a bit farther. But back to the listening... Once interconnects were changed, it didn't take long to tell that this was certainly in another league compared to the Magnavox 9304. I don't typically do reviews and don't follow some of the reviews terminology. What I have found, is that the power just seems effortless. Regardless of the types of music I have thrown at it. The bass tracks are solid, and clean. The clarity of the highs and the detail it provides is much better. I listened to an Elton John track and you could tell that he just slightly laughed when phrasing a word. Have never noticed that before. The bias and balance was on, right out of the box. As for the transformers, I've heard of the 3 second rule. If you can keep your hand on them for 3 seconds, they aren't too hot. The Bogen would probably allow me to put my cheek on them and not be a problem. I've been listening for over an hour now and the OPT's are not even lukewarm. The power transformer is cool enough that I can lay the back of my hand or my cheek on it and leave it there indefinately. It is no doubt a cool customer. I've driven it at times for hours and it never breaks a sweat. Funny thing about listening critically. The better the gear, the more the weaknesses show up. I noticed one of the Cornwalls seemed a little muffled in the higher frequencies. So I went through the whole cabling, wiring on the amps and speakers, (fearing it could be an amp issue) but it stayed with the same speaker. So off came the backs of the Cornwalls. After switching the tweets, it still stayed with the same speaker leading to believe it was a crossover issue. Then I remembered that one of the tweets screwed on farther than the other. Looking closer, threads had been crossed on one Cornwall and the tweet did not screw on near as far which affected the highs. I pulled the horn, got the tweeter threaded on straight and problem solved. I didn't realize that the depth of a few threads could make that big of a difference, and hadn't noticed it at all with the Maggie.
So I will continue to test and review. I have yet to get the Dynaco's hooked back up, and quite frankly, I feel no need to do that. This amp is so solid, clean and powerful, it has no doubt taken it's place as my main player. I will at some point attempt to compare it head to head to the MK III's but for now I am very, very happy with the new Bogen. I took a peek under the hood and it is more like artwork. Positioning of components and lead dress is impeccable. The amp performs flawlessy on all types of music with detail and strength. I can try the 3 different pairs of speakers and that each add their own character but can all be driven to ear damaging levels if asked. Anyone considering if this amp is a worthwile candidate for HIFI, I can say yes! YES!!! Sorry my review is not more eloquent, but it doesn't just sound good, it sounds great. I am forever indebted to Dave for his masterful work and his generosity of time. I'm glad he loves his work, because I could never afford anything like this if I would have to pay by the hour. I don't know what the $2k and $3K amps sound like, but I doubt they are going to sound any better than this big guy. Thanks Dave and thanks all for following along. When and or if I get to run it side by side with the MK III's, I will give a comparo here.
