Thank you Dave
Yes I have had many years with these amp and as I have used them for years without any issues, I used a few of the vent holes to mount cathode test points to test balance before operation.
The article I was looking for had to do with grid stop resistors and parasitic oscillations, if I recall it was the control grid that would start to overload when the amp was driven over the point of bias voltage sending them positive and draw current till they disintegrated and shorted..
I know the bias is low on these tubes due to the high trans-conductance and the better choice would be something with a lower trans-conductance to handle the drive voltages without going positive then into overload.
I was always one to use a loaded tap for the feedback to keep the linearity in the af stage but I dont understand the separate winding for the FB...larger r/c to keep the 17db...
I was thinking that the fb loop was always a issue driving the amp into overload off the 70v tap as opposed to the 25v tap with the inductive load to tame the transients to the af stage.
How was the amps distortion if the fb was open, is there possibility of it being unstable?
Any other issues that may be encountered is the instability at the low frequencies, possible motor-boating and oscillations with the fb removed?
Another thing I took advantage of in the amp is the screen switching to put the amp in standby so there was no load on the tubes during intermissions.
I really haven't seen many engineers use this tube in designs probably due to its late entry when transistors were introduced...less than a handful. i'm sure if it had a history like the EL34 or the 6L6 there would of been better designs..
I noticed the the af section doesnt have a cathode capacitor probably to much gain, but it would possibly enhance frequency in the lower regions, most likely have to reduce the fb to reduce the gain..
Another thing I been studying the Stromberg APH 1200 schematic and seen they applied separate plate and screen supplies, screen supply is doubler design that also feeds the front end, what do think about this, besides the noisy 7199?
What do you think to incorporate on the chassis?
