do you mean the platter or the matt? Almost all cast aluminum platters (including the 1200 ring like a bell when tapped with a pencil. If you all a brass platter matt to the aluminum platter then add the rubber mat on top you'll damp the aluminum platter very well. KAB used to sell a similar platter matt. Not sure if they still do or not. If you have not replaced the main bearing you may want to consider doing that first.Hi All. Not sure if this is okay to post here or not, but I'm looking for a replacement platter to fit a 1200mk2. If anyone has or knows of one, please point me in the right direction!
question on the KAB damping trough: doesn't it get the way of the VTA adjustment ring?
It will obscure the index mark. But you can still see it looking sideways under the trough. It doesn't hinder the movement of the ring.question on the KAB damping trough: doesn't it get the way of the VTA adjustment ring?
God I loathe that kind of music. I know it's all subjective but I find it hilarious that people who are obsessive about audio quality want to listen to something so ugly sounding!Something About You.
Level 42. "World Machine." Polydor 28MM 0465. Polydor KK (Japan) pressing. 1985.
Run-out: V 〄 Ⓑ 28MM - 0465A 1 1 1 ✲ K R S
Subwoofers on.![]()
Truly unbelievable sound!!!Something About You.
Subwoofers on.![]()
This isn't meant as a negative or a dig, we all have the right to listen to whatever, just find it interesting and interested to hear other people's thoughts about audiophile standards vs. Taste.
I have the GR2 and don't see any need for a fluid damper... a tonearm lifter IMO is a much better accessory. Since I installed a heavier cartridge (AT-VM740xML at 9 grams) I was able to add the 10 gram weight to the end of the tonearm then move the counterweight very close to the pivot point- the arm doesn't do the tiny Left to Right wiggle anymore.question on the KAB damping trough: doesn't it get the way of the VTA adjustment ring?
I haven't seen the need for a fluid damper for my Technics or SME arm. I like keeping things OEM. Call me "Mr Square Peg."I have the GR2 and don't see any need for a fluid damper... a tonearm lifter IMO is a much better accessory. Since I installed a heavier cartridge (AT-VM740xML at 9 grams) I was able to add the 10 gram weight to the end of the tonearm then move the counterweight very close to the pivot point- the arm doesn't do the tiny Left to Right wiggle anymore.
What music don't you loathe?God I loathe that kind of music.
An all time 80's classic ! I love most of the 80's music because there were so many "One Hit Wonders" that there was always something fresh to listen to, I never got bored hearing the same old songs over and over and over (like the "Classic Rock" radio stations we have today).Great tune!!!
