Generally, yes, but even 3" is large enough for these, since there's a pair of them.From what I've always done with ported cabinets, the larger diameter the port (within reason) is better because there is less port noise. Is that a safe assumption with these?
I shouldn't have used the word "baffle," because that's not the issue here. It's a step/shelf filter comprising an inductor in parallel with a resistor, the combination in series with the driver.School me. What's an LR baffle step filter? Got a link to what I'd need to build to do that? Can you graph the response results with that filter attached?
The intent is to level the rising response of the woofer, if that's real. Somebody's going to have to measure to determine the actual performance of 416-8Z in that box size and tuning. A notch filter may be required instead, one more component. You give up woofer sensitivity to acieve flattened response, but there's a sense in which that sensitivity is illusory, anyway, since it is peaking in the lower midrange and not balanced with the available lowest frequencies.
See Dickason 7.70, "Contouring Filters."
It does look like a fun project though. :thmbsp:
