I've run into several instances where repairing direct-drive turntables has simply not been practical, due to death of the control IC.
The three most common victims, have been JVC, Denon and Dual. I've had models of each, where EVERYTHING right up to the control microprocessor tested good. It's funny... they almost all seem to have the same failure mode- the platter starts to spin up to "warp speed"... instead of 33.33 RPM, it's like several hundred RPM. The motor just goes to max speed, for whatever reason.
And with some of these using what looked to be 30-pin and larger chips... there's a LOT of stuff that would have to be recreated to make it work.
Other problematic tables have been Thorens and Linn, with the servo-generator running their belt-drive motors. Same issues... dead mystery chip, either no motor operation or erratic fits and spurts.
Most of the time, it's a matter of the time and money not being worth the effort... compared to buying the same entire turntable over again...
This is why I'm a big fan of turntables like the AR-XA and such. An AC clock motor, a belt, and a platter. NO WAY that can't be fixed, somehow... and IMHO, they sound better too (less noise).
It's funny, again... how some turntable manufacturers have turned a basic, reliable design into a complicated mess that is virtually un-fixable. This is definitely the case with the later model automatic Thorens models, and any of the more modern Linn turntables. When they went away from synchronous clock motors to complicated DC servos, they lost the dependability that they once had... and IME, they didn't sound any better, either, for the most part, with the DC motors...
Regards,
Gordon.
Regards,
Gordon.
