G'day all, certainly my experience of listening to live music in a good acoustic venue, is one of 'warmth' :yes: Regards, Felix aka catman.
rolled off high is an inevitable aspect of live acoustic music which explains why it might sound warm.
Actually, slippers-on, I'd say your speakers are uncouloured and neutral, having heard them several times. Your amp, too, unless Rotel have changed their sound, I wouldn't say was particularly coloured either. Whether your preamp introduces distortion in the sense of warmth, given it's a hybrid, is another matter, but at face value you seem have a neutral system.
Nice system, by the way. I've always intended to buy German gear, and Canton have always been big on my radar.
)....if you've heard Canton and liked it, then you and I are talking the same language, but describe it differently.:thmbsp:Hearing a $100,000 system that's described as "totally flat" doesn't mean it was designed to emulate the sound of the original recording, however.
I assume it means it was designed to reproduce the incoming audio signal as accurately as possible without adding/subtracting anything.
Two different animals.
Can anyone play back vinyl and make it sound like digital, or even just like the master tape that was used to cut the master pressing?
BTW I often hear that vinyl is more accurate than digital. Given that there is always discussion of the different "sound" of cartridges, phono preamps, platters, mats, bearings, etc., how can this be so?
Given the choice of 3 TTs, 3 carts, 3 Preamps and 3 tonearms, you have 81 possible combinations alone that can produce widely varying sound.
There's a lot more variety than that out there (I'm guessing tens of thousands of possible combos).
Not all CD players sound the same, but the differences seem to be focused on overall accuracy in playback, the ultimate goal being identical reproduction between all players.
Kind of odd...
I'm not convinced Digital has a sound as such. Certainly my Clearaudio gear doesn't sound a mile off my digital, and vice versa.
The Builder of the system told us personally he built it to be free of any coloration whatsoever. His speakers where huge Klipsch Horns with that extra tweeter sitting on top. We heard the system at moderate levels and ear bleed levels. It was sterile as can be to my ears and to the guy who was with me.
I wouldn't be shocked if some people found a reference system room set up by, say, JBL Synthesis, or KEF, or TAD to sound "sterile", but setting out to put together a reference system "free of coloration" around Khorns sounds like something of a losing battle to me...
. . . setting out to put together a reference system "free of coloration" around Khorns sounds like something of a losing battle to me...
An upgraded Emotion - Unify tonearm, ceramic bearing and upgraded feet. Clearaudio Concept 2 cartridge.
Sounds as good as it looks!
It's kind of tough to get my point across, but what I meant was that his attempt at a lack of coloration doesn't factor in the sound of the original environment (if one existed when the recording was made. i.e.-live music in a club, studio recording, etc.).
Take a flower that looks absolutely beautiful outside in your sunny garden and put it in a vase in your kitchen under incandescent lighting. The color of the flower is identical to the original, heck it IS original, but what you SEE is not going to be the same.
Take a Grand Piano and play it in a concert hall, then play it in your living room.
The notes may be identical, but the sound will be anything but (maybe the reason you were left unimpressed by the "perfect" system).
Maybe it was EQ'd to be too "flat", disregarding the natural high-end rolloff mentioned earlier (smae reason why THX re-EQ is needed for home environment- the theater size provides that natural rolloff).
Lots of possibilities.
I've owned "classic" period Klipsch and they are anything but neutral sounding whether amplitude-sweep-flat or not. The pulse response of these things is also a mess and I long ago left them for speakers less prone to imprint their personality on the sound and with far better time and phase response. A "standard" of anything but amplitude response efficiency they are most definitely not.The other shocker was finding a system including Klipschorns to sound sterile. It must be possible, since that's what he heard, but those speakers have always sounded very involving to me. Maybe the extra tweeters sitting on top and the lack of a turntable were partly to blame.
They may not be free of coloration, but the classic Klipsch speakers can sure make some nice music.
"In a contradiction of received wisdom, it turns out that some of the classic horn loudspeakers show much greater musical integrity, judged in terms of natural pace and dynamics, than do the majority of low-sensitivity, low-coloration systems now produced. Come back, Klipsch and Voigt, all is forgiven! Those designers' belief in outright sensitivity, and the qualities of linearity and uncompressed dynamics which this single factor confers, are still not properly valued by the high-end industry." http://www.stereophile.com/content/pace-rhythm-dynamics-page-3
I think that's the point a couple of us were making, that we found it somewhat strange that someone would choose to use Klipschorns when the goal was "to have no coloration what so ever," (and Slippers-on defined "sterile" as being, in part, free of any coloration whatsoever). I used Klipsch La Scala for a couple decades, and no, it's not a low-coloration speaker, but it was able to play music that drew me into the performance and was far from lifeless.
Perhaps you'd be kind enough to define your terms:
pulse response
How do those characteristics relate to the virtues of natural pace and uncompressed dynamics that Martin Colloms attributed to the classic horn speakers in the quoted excerpt that I assume you were responding to?
Those factors relate to sonic accuracy aside from efficiency, otherwise look up pretty much anything on speaker testing by Ed Long.
It gets complex as the phono stage can be a definite factor here too. Indeed one of my kit phono stages 'sound' always reminds me of being in a deep freeze, even when teamed with an M97xE! What are others preferences that way? Warm or cool, or something other? :scratch2: Regards, Felix aka catman.
