cafe latte
Addicted Member
How much was the Swiss black?Have several, that one is specifically the Ogura Vital PE elliptical….that’s the reason I corrected the post.
Chris
I have the denon 103 from VAS on my SL1210 mk2 . It sounds great but I know my arm is too light. Since I like the 103 sound which denon cart would be best for my medium compliance arm?
Interesting thread. Thanks to the OP and contributors.
I have only used one brand and model of MC cart since I was in college. I bought a new Yamaha CA-810 amp the summer between my Sophmore and Junior years, and the 810 has an MC input. So I also bought a Yamaha YP-D4 direct drive table and an Ortofon SL20E MC Cart from a local stereo shop close to my college. Big bucks for me back then.
A few years after graduation and with some career money in my pocket, I went back to that same stereo shop and they were closing out that same cart for a whopping discount, so I bought all they had. I am actually now on the very last one decades later, and I expect it to last me until I will no longer be spinning vinyl. I do not use that Yamaha system very often these days, so the MC cart gets very little use.
When I was under high quality headphones with younger ears, I used to believe I could hear a difference between MC and MM. However, I probably would not have gone down the MC Cart rabbit hole if that Yamaha CA-810 had not had an MC input. There are some very good MM carts on the market, and at my age under most listening conditions, I doubt that my ears can currently hear any difference between MM and MC.
I'm 65, born 1/2 deaf in my left ear and my hearing hasn't improved with age lol, and I can easily hear the difference between every cartridge I have. I should mention I've worked in some very noisy environments, for example, construction, machine shops, and a tire mulching facility just to name a few.
I believe you're selling yourself short on just exactly what your ears are capable of discerning.
Back in the day my first MC was a modified (Paragon Pulse bodied) DL-103 on an SL1210 mk2. There's a lot that can be done with that arm to make it work better than just fine with the DL103. KAB sells heavier auxiliary weights for the back of the arm and a roll of lead tape adds even more to make it work. I also added their fluid damper to that arm.I have the denon 103 from VAS on my SL1210 mk2 . It sounds great but I know my arm is too light. Since I like the 103 sound which denon cart would be best for my medium compliance arm?
Adnick, It seems like you have a lot of experience with the 103 family. Do you think the "D" would be better on my table than the original 103 with the added weight on the headshell ? Do you use VAS for re tip's ?I’ve personally found the 103D a good fit on a medium arm it’s the only 103 I own that’s stock
I assume the D is not conical then. I was very surprised at how well the basic VAS re-tip did on my modest Emotiva pt-1 line stage switched to the MC setting. I also have a Hagerman piccolo head amp and an SUT by PJL electroncs.
Which MMs would you suggest instead of the Rega Exact and why?
I can answer this, the Rega is total junk, if you open one up ( I have) the coil former looks like a bent coat hanger and probably is. Thr coil looks like it has been wound by a chimp. Then thr stylus has no tieback, it is thick and heavy and they are not glued into the suspension so they creep out, move back and forth and rotate.
The cart us far from flat response no matter how you load it. It is utter junk.
Re alternatives?
Literally anything is better.
Chris
I've been using MC cartridges exclusively for almost forty years as they tend to offer better transparency.
Certainly not to be found with my Dynavector rated +/- 1 db full band.Yes, however in some cases the 14KHz-18KHz resonance, which would be artificially masked on a correctly-loaded MM cartridge, is giving a false sensation of "transparency".
https://www.dynavector.com/products/cart/e_20x2.html
The load used was not stated which renders that graph questionable. Indeed, it does sound a bit bright at higher load impedance values without sufficient damping.A quick google finds a sample of an Actual measurement:
That is very true, witness the $99 high output SAE MC carts that were on the bay a few weeks ago....now those were really special deals, but if you keep an eye out, you can find others.
