Andy—Please weigh in with your experiences of either/both (and especially compared to a refurbished 301^^^—which would probably be my first choice).
When I discussed buying a refurbished 124 from someone who makes his living refurbishing 124s and 301s, he said he could not honestly recommend getting an old 124 because of the troublesome, noisy motor. He told me to get a 301. When I asked about the 124 DD, he gave it extremely high marks and said he couldn’t say anything negative about it and would definitely recommend it over an original 124.
Thoughts?
Can’t speak to the 124 DD, and wouldn’t want one, but there’s certainly a reason the original TD124 is so revered. With the aftermarket parts and some maintenance they are excellent machines. If one can do the work yourself then it’s between $300-400 depending on motor condition, of course one can go deeper with a special bearing housing and electronic speed control….
Mine has all the Audiosilente parts, but went with the gummy motor mounts and used Delin bearings in the platter shaft well, plus a custom constrained layered plinth, it’s now extremely quiet, as quiet as my Denon DP75…
In stock form, good working condition, a 301 grease bearing is the quietest idler I’ve ever encountered….
If you can put your hands on a 301 grease bearing then that’s what I’d recommend and there’s arguably a slight edge to having an early rimless motor. Yeah the chassis may not be quite as stiff but a well made plinth will make up any percived differences, plus the raised letters on the black emblems are gorgeous
Any 301 or 401 for that matter can be taken to extreme heights with the high end parts from Classic Turntable Company
https://www.classichifi-shop.co.uk/ Their new upgraded bearing housing is fantastic, add a heavy Shindo type platter and it’s a dream machine, plus all that together is probably much less than a TD124DD
The heaviest platter I’m aware of is about 27# and would require an upgraded bearing housing, but the big Garrard motor will handle it…
Don’t know what your budget is, Ray at Classic Turntable might have a refurbished hammertone rimless available and he’s a fine fellow to deal with (no affiliation)
Really doubt that many people with vintage TD124s have purchased the new TD124DD, but there’s always exceptions
VR
Andy
