AudioJag
When the stylus is on the record?
So am I to assume the clutch is engaged so the record isnt spinning (otherwise how would you hear the "hum")?
If so, you might not be hearing "hum" in the electrical sense but "hum" in the mechanical sense.
As usual, I haven't been clear enough. Thanks for bringing that up.
I can clearly hear the hum when the record is spinning with the stylus playing on a record. It's hum that shouldn't be there. I also can hear the hum when the clutch is engaged and the stylus is on the record (plus the platter turning below and other issues we don't need to worry about now
