I understand that you say the cost of having the motor rebuilt is prohibitive for you. Have you considered buying the parts and doing it yourself? Here is my thread with a step-by-step for doing just that: http://www.audiokarma.org/forums/showthread.php?t=588789
Note the decrease in motor noise that I achieved. From what you've said, I think this should be your focus.
this guy makes them. I've order stuf from him in the past from italy.
http://www.ebay.com/itm/CONVERSION-...Home_Audio_Impianti_HI_FI&hash=item3cd1d6f259
May be other sources in the US.
From this video: https://www.youtube.com/watch?v=xIrYWc6zyBo
It looks like you have to convert the motor mounting post size to be increased before you put on the springs.
Is this correct??
Can the conversion posts be bought somewhere cheaper than from the Rome site:
If you are trying to spend your audio dollars safely on this restoration project I would urge you to be absolutely sure where the noise is coming from before throwing your dollars at it. From what I see the conversion kit and spring system is going to be as expensive as a motor rebuild.
So buy an inexpensive stethoscope, or borrow one from an auto parts store if possible, and start listening to the critical parts of the turntable. Try to determine for sure where it is coming from, whether its the motor, the spindle/bearing assembly, or the idler wheel. If it is a mechanical noise, it would seem to have to be one of the three suspects...but the question is do you really know which one it is?
I don't think I have ever recommended this idea to anyone else. But from the get go you do not seem enamored with the TD 124. In un-restored condition they are worth over a kilo buck if in nice cosmetic condition. If you already have a go to table, perhaps it is just best to sell it and allocate the funds to a properly functioning second table and doing a few upgrades or maintenance to the rest of your audio gear Perhaps a couple of new cartridges could be in the works. That way you don't spend money on a table you are iffy about, and you put money into your audio kitty. Never recommended that to anyone about a TD 124, but it sounds like it is not your cup of tea you know?
Regards
Mister Pig
I agree with the above. A more methodical approach is called for here, rather than throwing money at it, hoping that a perceived upgrade will fix a still-undiagnosed problem.
Your first step if you plan to keep this table has to be a motor rebuild; that is just basic maintenance. It may also quiet the motor down, fixing the 'hum' that you are hearing. There is no sense in buying upgrade parts (ie: fancy motor mounts) unless you know for sure which of the stock parts are failing.
Let me reiterate that a properly serviced TD-124, even with stock parts (in good condition), should be pretty darn quiet. Rumble is not something that you have to accept.
audiojag,
I've owned several rim drive tables and none of them have been as quiet as a good Belt or Direct drive table. It is no coincidence that manufacturers had to abandon this method (except for tables intended to be mounted in massive consoles) in order to achieve the noise figures required. Also, you'll notice that in the TD125 the motor is mounted to a different plane than the arm and the platter.
I have a td124 MkII. That is mounted solid to a fairly heavy plinth. The motor needs to be cleaned (I have a kit waiting time to do it). This is not a dead quiet turntable nor would I expect it to be even with its "stock" mkII grommet setup (40+ year old gromets) and a freshly cleaned motor.
However improvements can be made. Here is an excelent article to reveiw.
http://www.hanzehifi.nl/merken-bezigheden/thorens-garrard/thorens/td124
Since these measurement were taken in the Netherlands I would only assume doing them in the US would produce 120hz hum instead of 100Hz hum. They did seem to get the hum down to -76db which is actually Direct Drive type figures but remember thats just the noise from the motor and is not measured with the belt and all other mechincals running.
I don't think folks use these tables becuase they are looking for a quiet solution. I find that even though my td124 is not a quiet as my other tables I do prefer to use it. I think there may actually be something to a flywheel spinning, directly coupled to a fairly heavy platter being a superior musically but inferior from a Signal to Noise ratio. Granted it may just be my imagination.
Steve
I tried them all. The rubber motor mounts, silicone motor mounts and ended up replacing them with a spring setup instead. That's where I heard the most improvement.
Maybe I can also find a simple stethoscope and check other things.
Harbor Freight sells them for about $8 IIRC. I bet that any auto parts store will have them too.
" Originally Posted by Mister Pig View Post
Have you removed the belt and checked to make sure it is indeed a mechanical issue with the motor that is causing the noise? If it is motor related then it should still appear with the cartridge just resting on the vinyl and the motor turning. And then the question becomes is it possible to deal with the issue with the motor mounts. "
I'm going to try Mister Pigs suggestion quoted here as a first step later today. Maybe I can also find a simple stethoscope and check other things. From all the suggestions that I've been receiving, and as in what others have done and the video link, the motor isolation ranks highest on the list as the most likely problem.
I'm inclined not to rebuild the motor yet as I'm a believer in "if it's not broke.... don't fix it" ..... I'm not convinced yet that the motor needs rebuilding... although I'll keep an open mind about that.
