dnewma04
The Healer
if a port and PR had the same cross sectional area, the mass would be the same. Since that would typically require gigantic port lengths, they end up being significantly larger (rule of thumb is to have PRs capable of displacing 2x as much air as the woofer) so either you use a single large PR with massive excursion or multiple smaller PRs.
Here are a couple of simulations of the woofer excursion between equally tuned PR and ported systems.
Depending on the PRs construction, the low freq behavior of the PR will change. In this case, it was a highly compliant PR with low Fs. Vintage PRs very well may look different.
