@Pete B:________________________________________________________
Just wondering, I'd like to know what woofers you have in mind, or even just the T&S parameters.
This all stems from the original idea of making a clone of the
AMT 3 Rock Monitor to feed my Heil jones. A good bass driver for the job seems
to be the Eminence 1040 SF 10", available at OCS. Mms is 45.79 gm, 2" VC,
sheet says "VC winding .750" - which I assume means it's inductance, at .750
mH.
VAS: 3.38 cu. ft.
QTS, FWIW: .38
FS: 29.88 Hz
XMAX: 9.1 mm
________________________________________________________________
How would you tune them (Fb) in the vented box, how large of a box did you have in mind?
I'd had in mind just duping the original cab & port dimensions, as everything
was well scienced out by OCS and other AMT 3 owners.
That was the original idea. I since got to wondering if it would be
worth the effort to go instead to a TL cab/mid-bass/Heil combo, as I want
to frame the Heils in the best possible way.
Box size and where did you plan to tune the TL, basically l/4 freq?
Whatever box size works - WAF not an issue. It could have a footprint
like an AMT 3 and be even taller yet. I'd prefer it be not crazy big like
the largest Polk SDA's. Other than that, I'm easy (or so they tell me).
Where tune it? 25, 30 Hz I imagine would be fine, if that's what you
mean. Tuning lower would be OK if critical to the design. Whatever
makes the driver I go with happy & accurate/articulate enough to
blend well w. AMT's.
I just don't want to have to add subs.
Is there a commercial speaker that you particularly like?
Sorry if I'm being obtuse here, you mean drivers or built speakers?
If drivers you mean pro-line (JBL/EAW) or home market OEM/DIY
like Audax/Scanspeak & so on?
FWIW, in general I usually prefer a good BR cab
to sealed, hate horn-loaded anything or band-pass, and have never actually listened
to any TL's, but they look good on paper. Nicest (if not fastest)
mid-bass to my ears is probably the 8" JBL L116-A they used to put
in the L-19 & such. I owned some modded JBL 4311's that I quite liked
for their bass. Most of my life I never had time and/or money to
listen to home stuff too much more up-market than that. But since
'80, '81, I've loved the idea of mixing Heils with quality bass & lo-mid
drivers. Now I do have more time & money to go for that plan.
