keflover615 Active Member Jul 24, 2009 #1 I have a Thorens TD 145 w/a broken tone arm and a Thorens TD 115 w/ a TP 16? tone arm. Can I take the tone arm from the cheap 115 and install it in the 145? Any help would be appreciated.
Bluespower Active Member Jul 24, 2009 #2 Your TD115 should not have a TP-16 on it. If for some reason it does, it could be used, but the stock arm for the 115 would be incorrect. http://www.vinylengine.com/tonearm_database.php?make=Thorens&sort=manufacturer&ascdesc=ASC&type=1&pass=null&Search2=Search
keflover615 Active Member Jul 24, 2009 #3 I guess I was mistaken, the manual says it is a TP-30, can I use it?
