VintageDutch
Thanks for the correction on your unit re direct drive. My Rotel is a "beater" simply for fun and I encourage you to try damping the arm and see if you like it. A quick way to check if basic damping makes a difference or not is to use "friction tape" which is available at hardware stores. It is adhesive impregnated cloth, acoustically dead, and any residual goo when you take it off cleans up instantly with alcohol. It wont address low frequency ringing but it does work on mid and high frequency resonances.
Try spiral wrapping the half of the arm closest to the pivot or two or three rings of tape in strategic places. You might be surprised at how much of the sound of your cartridge is actually the tonearm. You might hate the results but it only cost a few dollars and is easily reversible without leaving a trace. If it makes a difference and you like what you hear then welcome to the rabbit hole. And of course there will always be folks here that insist damping is a waste of time/always worth doing, that mods make turntables better/mods are stupid, etc. I say have fun and enjoy some great tunes.
@psemeraro It was not my idea to correct you but simply state the differences... Those are essential for the choices needed.
The Friction tape idea is not at all a bad idea... I did an experiment with Rubber O-ring's on the tonearm to battle the tonearm sound but it did not make an difference to me... maybe I placed them wrong or they had not enough mass...
Ill dive back in If I can find that tape over here in the Netherlands Thanks!
