Does the opamp upgrade make a big difference?
Yes, it does...and, you don't have to use big bucks Sparkos, the Muses was a step up from stock, I may find my set of Burson V5i's and try them some day...
But this little amp is fine into my ProAcs.
Do you have a link for the Muses?
@drjohnnyfeva. Lots of counterfeits on the bay.
Do you have the seller info for the reliable one you use?
Thanks
Poultrygeist, did you swap out the opamps in the A07?
Not yet. I've hesitated because even with the rather expensive opamps I'm not sure it will come close to the Volt+D and FX tube preamp. Have you tried that combination?
What pre-out from the A-07? I thought it only had speaker ouputs for stereo speakers?A few hours ago I fronted the Aiyima A07 with the FX Audio Tube-01 for some added lushness in my near-field system. Diana Krall's voice can be a bit edgy/raspy in the upper registers but the 01 adds some nice tube smoothness. This is nice improvement over the SQ I was getting before with the A07. The Mark Audio drivers in the Frugal Horns are very revealing and it's easy to notice a change especially when it's for the better. The wooden box attached to the A07 stores its power supply and keeps it from falling off the table. I really appreciate the powerful signal the A07 sends to the sub from its pre-out.
Added the Volt+D to my main OB system driving Lowthers and Lii Audio F-15s and wow am I impressed
